2500 Coil Springs on 1500 2wd
Old 03-16-2012, 10:37 AM
Dbrown016's Avatar
Dbrown016
Dbrown016 is offline
so if i were to put the 2wd 2500 springs would i need longer shocks or not?
  #22
Old 03-16-2012, 10:42 AM
Dbrown016's Avatar
Dbrown016
[QUOTE2wd springs will all interchange (except maybe the solid front axle springs). You'll get like 3/4" from gas springs and at least 2" lift from V10/diesel springs (the ride will be terrible).][/QUOTE]
so the springs wont matter is it is diesel or not? becuase if they dont i may be looking to buy your springs grox
  #23
Old 03-16-2012, 12:15 PM
grox's Avatar
grox
grox is offline
The only difference in the springs is their weight (thickness of the coils). There are 3 different kinds for the independent front 2wd suspensions, one for each of the GVWRs, which are 6400# (1500 models), 7500# (2500 V8 models), and 8800# (2500 V10 and CTD models).
  #24
Old 03-16-2012, 12:19 PM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
Many v8 2500's were 8800# GVWR trucks. Like mine, for instance.
  #25
Old 03-16-2012, 12:22 PM
grox's Avatar
grox
grox is offline
You will not need longer shocks if you change out the springs since the springs are the same length, anyone who tells you otherwise is wrong. The lift comes from the lack of sag from the stronger springs. You will need new shocks rated for the heavier springs, but they are a sock shock.
If we work out a deal for the springs I'd be glad to send the shocks along with them.
  #26
Old 03-16-2012, 12:25 PM
grox's Avatar
grox
grox is offline
That may be true, the springs though should go along with the rating of the truck. The stock part number for V8s is for 7600# for the 2wd front ends.
  #27
Old 03-16-2012, 12:33 PM
Wombat Ranger
Interesting. When I look up that kind of stuff it always gives two part numbers, one for each GVWR. Is there not that option with 2wd's?
  #28
Old 03-16-2012, 12:36 PM
grox's Avatar
grox
grox is offline
Not as far as I've found, it definitely is an option for the 4x4 trucks. I could be wrong. At any rate (no pun intended) all that really makes a difference is what GVWR the spring is for. There is a fairly dramatic difference between the 8800# springs and the rest of them.
  #29
Old 03-16-2012, 12:39 PM
Wombat Ranger
Learn something new every day!
BTW puns are some of my favorite humor. They take brains to understand
  #30
Old 03-16-2012, 12:59 PM
grox's Avatar
grox
grox is offline
They also can sneak up and surprise you. I've said many funny puns without even realizing it. I always play it off like I had thought of the pun too when people laugh.
Quick Reply: 2500 Coil Springs on 1500 2wd
