95 ram 1500 detonation
Old 02-14-2012, 05:17 PM
camd94234's Avatar
camd94234
camd94234 is offline
Post 95 ram 1500 detonation
ok so my brothers 1995 dodge ram 1500 5.9l 4x4 is detonating cylinder #8. what could it be? my dad has changed the cat because the cat was bad and he was driving around with the bad cat so could the driving around with the bad cat have made it so the #8 cylinder is detonating? i was thinking that the knock sensor could be gone but i was looking on autozone and they do not show a knock sensor for this model so i am stumped i have no clue what it could be? any suggestions???
thanks,
cam
Old 02-14-2012, 05:25 PM
stewie01's Avatar
stewie01
stewie01 is offline
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Probably need to check out the plenum and PCV valve.
Old 02-14-2012, 05:33 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
^What he said.
There's no knock sensors that's why autozone doesn't show 'em, so don't worry about that.
You're brother's truck is probably a little low on oil? If the plenum is blown, it will cause loss of oil, detonation, a bad cat, misfires, lack of power, etc... the new cat will go bad (after a while) if you don't fix the plenum/pcv, if that's the issue. So definitely look into it.
Old 02-14-2012, 05:37 PM
gdstock's Avatar
gdstock
gdstock is offline
Looks pretty much like the plenum...So
Old 02-14-2012, 08:51 PM
BigBlue83's Avatar
BigBlue83
BigBlue83 is offline
From everything ive read id 4th the motion of plenum two main sighns... Spark plug 8 and clogged cat
Quick Reply: 95 ram 1500 detonation
