Code P0740
Old 02-10-2012, 07:17 PM
Old man 62's Avatar
Old man 62
Old man 62 is offline
Default Code P0740
Ok so where's the torque converter lock-up senser. Inside or out, I'm getting a P0740 code. It shouldn't be the hard to fix if you know where it is. Thanks for any help.
Old 02-10-2012, 10:42 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
need more information about your truck man
specifically which transmission do you have? if you dont know the numerical identifier (44, 46, or 45/545) give us the engine and we can figure it out from that.
Old 02-11-2012, 03:28 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Old Man 62
I do have PDF files for these and all codes with your transmission, All I would need is your email address to send it too if you want them. That also goes for everyone else. All you have to do is ask. Here is the information from old man 62 on another post. Then I going to delete the other post.
I have a 2001 Durango 4.7, 45 or 545. Jeep TCM. Code say's that the torque converter solenoid circuit has a problem. will pull all conections and clean. Also need to replace the power steering pressure senser, Code P0551. Only getting 15 MPG on open road, don't think it's locking up.
Old 02-12-2012, 01:13 AM
Old man 62's Avatar
Old man 62
Old 03-09-2012, 12:44 PM
tst31's Avatar
tst31
tst31 is offline
I just pulled the same code on my scanner yesterday, coincidentally. I do not know what transmission I have, but I do have the '99 5.9L, 4WD. I would also like the pdf's, please. I just bought this truck a couple of months ago (my second 5.9L 4WD) and recently had the transmission/transfer case fluids changed, only to find out the transfer case has a lead that apparently requires a seal to fix. I will be taking it back to my transmission guy and hope to have him fix this issue at the same time. Thanks in advance!
email to tst31@sbcglobal.net
Old 05-21-2012, 02:28 AM
iwa2002's Avatar
iwa2002
iwa2002 is offline
I'm also having the same problems plus a few others, codes P0700, P0740, P0738.. Its a 2002 Durango 4.7L, 2wd.. Multi-Speed Auto 45RFE Transmission. I know what the codes mean. I hear alot of recommendation, has anyone found a quick fix. I could also use a copy of your pdf.. (Old man 62). Thank you,
email.. r_iwa2000@yahoo.com
Quick Reply: Code P0740
