Old 08-12-2015, 02:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
Print Wikipost
Passenger Door Heated Mirror Not Working
Old 02-08-2012, 12:55 PM
joker055's Avatar
joker055
joker055 is offline
Question Passenger Door Heated Mirror Not Working
So despite a weak winter we finally got some ice/frost bad enough I had to use my defroster and heated mirrors. That's when I noticed that my passenger side mirrior was no long defrosting.
Anyone else had this problem come up? Cost of dealer to fix and/or do it yourself? Instructions would be great as I have no idea how to take mirror apart.
Thanks guys!
Old 02-08-2012, 01:18 PM
InterpunX's Avatar
InterpunX
InterpunX is offline
That happened to me before but luckily my truck was still under warranty. I brought the truck in and it was fixed at no charge. Other than that I can't help you, maybe bring it in and see what the dealer says, and get a quote for a new part. If you do a search on this forum I know for a fact there's a really good DIY on out to take the mirror apart. Good luck
Old 02-08-2012, 04:55 PM
Pedro Dog's Avatar
Pedro Dog
Pedro Dog is offline
The mirror glass part can be removed fairly easily but you must be careful. Two weeks ago, my wife came home and said she needed to show me something with the truck's passenger mirror. The mirror glass had gotten loose and was just hanging by the electrical wires. I don't know how it happened. The bottom of the mirror has two tabs that fit into small openings on the bottom of the the electric mechanism that turns it, the top has two snaps with little tabs that snap into to openings on the mechanism, the defroster is a heating wire connected to two wires coming from inside the door. I centered the moving mechanism, put the mirror's bottom tabs in at the bottom of the moving mechanism, aligned that upper snaps with the openings and pushed till I heard a snap.
I think if you wanted to remove the old glass, use two pieces of wood like paint stirrers and insert them at the top of the Glass about 1 inch from the corners and gently force the snaps to pop out. Reverse the process for installation. I think once you remove the glass you can test it and make sure it's the heating wire before replacing it.
Old 01-03-2013, 02:07 PM
Hop's Avatar
Hop
Hop is offline
Did you ever get this fixed? Mines been doing this since last year, but I let it slide all summer long. Now to get it fixed out of the 3/36 I need to pay $100 deductible.
The drivers side works fine. So I doubt it's anything in the wiring? I thought maybe a plug or something on the passenger side came undone or something? Maybe a fuse-able link somewhere??
Old 01-04-2013, 10:38 AM
joker055's Avatar
joker055
joker055 is offline
Actually no, and now that winter is back i'm starting to think about this again. I'm guessing since this thread didn't get many hits it's pretty uncommon. If I ever get around to fixing or having the dealer do it I'll post an update.
Quick Reply: Passenger Door Heated Mirror Not Working
