Old 08-13-2015, 03:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Is There A Cabin Air Filter or Not?
Old 02-06-2012, 08:54 PM
Capn Preshoot's Avatar
Capn Preshoot
Capn Preshoot is offline
Default Is There A Cabin Air Filter or Not?
Subject line says it all. On a 2010 Ram 4.7L is there a cabin A/C filter (that needs to be periodically changed) or not?
If so, where is it?
Also if so, is it something you can replace yourself?
Thanks!!
Old 02-06-2012, 09:28 PM
Mikeyyy816's Avatar
Mikeyyy816
Mikeyyy816 is offline
No cabon air filter on these trucks bud. Some guys hsve done mods to make one.... Check out Dodge Talk forums and do a search and some guys have added them with a DIY install.
Old 02-07-2012, 06:09 AM
ripplek's Avatar
ripplek
ripplek is offline
TOOLS NEEDED:
(1) Sharp boxcutter or X-acto
PARTS NEEDED--
(1) Filter box 'lid'. Dodge part number 68052292AA (About $11)
(1) Cabin Air Filter. Dodge part number 5058693AA, OR, Purolater C25869 ($7), Hastings HAAF1328, or Wix 24578
(These parts are all "OEM" for a 2010 Dodge Avenger, Caliber, Compass, etc. They will not be found by searching in any parts book under 'Dodge Ram'!)
Step 1. Remove lower glove box by gently pulling inward on both sides where the 'ears' are.
Step 2. Locate the filter slot area, which is shaped like a short, fat "T". Using the sharp tool of your choice, cut out the area just inside of the "T". You do not need to cut out the lower 'leg' of the "T", just go straight across. (Refer to pic)
Step 3. Slide in filter with airflow arrow pointing down. The filter, when properly installed, will protrude outside of the slot some. It will not be 'flush'.
Step 4. 'Snap' on the lid. You will need to press on the little 'ears' on each end of the lid (marked with blue tape in pic) until you hear a 'click'. This 'locks' the lid into place.
Step 5. Re-install glove box, and done!
Attached Thumbnails Is There A Cabin Air Filter or Not?-cabin-20air-20install-20003-1-.jpg   Is There A Cabin Air Filter or Not?-cabin-20air-20install-20005-1-.jpg   Is There A Cabin Air Filter or Not?-cabin-20air-20install-20006-1-.jpg   Is There A Cabin Air Filter or Not?-cabin-20air-20install-20007-1-.jpg   Is There A Cabin Air Filter or Not?-cabin-20air-20install-20013-1-.jpg
Old 02-07-2012, 08:32 AM
thiggins's Avatar
thiggins
thiggins is offline
Get the WIX filter. It's a much nicer/better filter than the Dodge one. The Dodge one is kinda flimsy, and will easily collapse on you when you install it. The WIX is much sturdier.
I did the mod, it's pretty easy if you take your time. Be sure not to let any of the plastic to fall down into your air box.
Old 02-07-2012, 08:38 PM
Capn Preshoot
Originally Posted by ripplek
TOOLS NEEDED:
(some obvious snippage)
WOW!!!! Thanks for the great write-up & pictures. I just may try this.
Old 02-07-2012, 08:55 PM
Pedro Dog's Avatar
Pedro Dog
Pedro Dog is offline
I'm not trying to hijack the thread but I've been trying to understand your signature, LOL....so your wife wants you to drink and chase women or do one or the other?
Old 02-07-2012, 08:59 PM
Capn Preshoot
She calls my truck "The Other Woman" since I do seem to spend a lot of time & money on it. Hence she says she'd almost prefer I drank or chased women (than spend so much time screwing around with the truck)
Old 02-07-2012, 09:36 PM
Mikeyyy816's Avatar
Mikeyyy816
Old 02-07-2012, 11:34 PM
tobyjohnson11's Avatar
tobyjohnson11
tobyjohnson11 is offline
I did this mod too. It was pretty easy and I am going to check the filter after 5K miles and see how it looks. I got a NAPA filter.
Old 02-09-2012, 09:43 AM
seigell's Avatar
seigell
seigell is offline
I'm definitely going to have to try this Mod.
Driving backroads in the high desert turns my Ram into a "Vaccuum Cleaner" with seemingly more dust collected inside than left outside.
Quick Reply: Is There A Cabin Air Filter or Not?
