2000 dodge dakota sport 4x4 problems
Old 01-24-2012, 06:16 PM
zult's Avatar
zult
zult is offline
Default 2000 dodge dakota sport 4x4 problems
hi, just want to open by saying what i great forum this is,
I baught a 2000 dodge dakota sport 4x4 for $1000.00 because my body was bugging me to buy one so we could go 4x4ing, i got the 4.7ltr v8 magnum, first problem,
Problem 1: when starting truck there is a slight tapping sound, on acceleration it gets alittle louder, i have been reading alot of forums stating it could be a litter has fallen off, to a bolt broken on the manifold?
i was told to put in lucus motor oil and then top up with my regular oil will this help with the noise?
Problem 2: my power windows and door locks don't work when pushing the bottun up or down nothing happends but a clicking noise in the glovebox?
any help would be greatly appreciated,
Old 01-24-2012, 06:36 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Both the power windows and the door locks receive power via a circuit breaker, should be #20. Open the driver door and look on the lower part of the dash and you'll see it.
It may have failed. You can test it with an ohmmeter.
The tapping noise, is it worse hot or cold? It could be an exhaust leak, especially if it goes away as it warms up.
How is the oil? It can't hurt to change it and replace the filter while you're at it.
Old 01-24-2012, 06:47 PM
zult's Avatar
zult
zult is offline
i have left it running for 10-15 mins and it still does it, so about the doors and locks is it one relay? or one fuse? i do not believe it's an exhaust leak i have hade it up on a hoist and there is no leak anywhere.
Old 01-24-2012, 07:44 PM
dakotaguy1994's Avatar
dakotaguy1994
dakotaguy1994 is offline
if it gets louder the faster you going and the more you accellerate it could deffinatly be a cracked exhaust manifold...happened to one of my old trucks.
Old 01-24-2012, 09:49 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
The one circuit breaker does both the power windows and door locks.
Old 01-24-2012, 09:59 PM
zult's Avatar
zult
zult is offline
okay well that covers the windows and door locks, any more idea's on the enigine? all the reading i have done is eather let go lifter, oil intake pump, but is has good oil pressure, so any other ideas would be great
Old 01-30-2012, 07:57 AM
dbilik's Avatar
dbilik
dbilik is offline
Have you checked the exhaust manifold yet like others have said? If that's not it I would say you are looking at having to take off the valve covers, and the drivers side is a PITA. It's like one of those little brain teaser puzzles. Come's out only one way.
Smoke testing it would possibly be able to help you if the crack is large enough.
Old 02-02-2012, 05:27 AM
zult's Avatar
zult
zult is offline
it's not the manifolds it sounds more top end, i'm gunna be taking the heads off to check the lifter's, the other day i checked my oil and there was like a creamy white/yellow line on the dip stick what could this be? bad oil? bad filter? water in the oil?
Old 02-02-2012, 11:27 AM
bpark8824's Avatar
bpark8824
bpark8824 is offline
I would say water. I think this may be related to your ticking noise.
Old 02-02-2012, 12:04 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Creamy white/yellow on the dipstick is not a good sign. If you do a lot of short trips it may be from moisture not burning off.
It could also be a blown head gasket.
Quick Reply: 2000 dodge dakota sport 4x4 problems
