View Poll Results: Have you had good results by Grounding the TB ?
Yes
39
81.25%
No
9
18.75%
Voters: 48. You may not vote on this poll
grounding the TB ???
Old 01-17-2012, 12:36 PM
adventurer's Avatar
adventurer
adventurer is offline
Default grounding the TB ???
I read this at diablo sport forum ( written by white_lighting which is a professional in custom tuning ) :
several people have had good results with better throttle response on 04 & up Hemi Ram trucks by grounding the throttle body.
simple ground wire from throttle body mounting bolt to ground on firewall, sidewall, or (-)battery post and the throttle blade opens and closes faster.
seems to benefit shift quality on some Rams too.
What do u think ?? Any body tried it ?
Old 01-17-2012, 01:05 PM
wink2873's Avatar
wink2873
wink2873 is offline
youd think it'd have to already be grounded
Old 01-17-2012, 02:55 PM
nzornes44's Avatar
nzornes44
nzornes44 is offline
I know of some ricers and old muscles that have a crate efi that do this as well, but like wink said you would think this would already be done. But between the TB and the intake manifold which is plastic there Is also a rubber gasket therefore not being grounded as far as the factory plug not sure if that ground would count either. I'll give it a shot and see what results I get. Anyone else ever done this?
Old 01-17-2012, 03:16 PM
Blacksport's Avatar
Blacksport
Blacksport is offline
You would think if that was the case, everybody would be doing it. But, if nobody tries....
Maybe I'll have to give it a shot! I wouldn't think it would hurt anything. Like mentioned before, you'd think the plug is already grounded, but if it's a crappy ground, then a wire from the TB straight to the firewall would give you a strong ground.
Old 01-17-2012, 03:23 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
06Dak4.7Silver is offline
Interesting..see what happens and post feedback!
Old 01-17-2012, 03:38 PM
adventurer's Avatar
adventurer
Yes i agree with nzornes44 and Blacksport, me and my friend will also try it on our trucks
Old 01-19-2012, 12:28 PM
PhillyEagleKGD's Avatar
PhillyEagleKGD
PhillyEagleKGD is offline
I did this last night and to me, it makes a very noticeable difference. It really smoothed-out my idle, and definitely helped with throttle response as well. Took my about 30 minutes to do and I had all the materials, so it was free. I removed the Hemi hat and air filter cover to easily access the TB. Ran a 14 AWG wire from the top left TB bolt to the ground bolt next to the battery. Used 2 ring terminals and zip-tied it all down.
Placebo effect or not, it makes a difference to me, and since I am the one driving my truck, that is all that really matters right? I would highly recommend doing this "mod".
Old 01-19-2012, 01:21 PM
houseoftoes's Avatar
houseoftoes
houseoftoes is offline
Could you take any pictures of how yours turned out? i was also wondering if you have any mods or are all stock. My truck is stock right now but I found a dealer to get rid of the MDS and do the fog light deal with my 08' in one shot.
Old 01-19-2012, 01:27 PM
adventurer's Avatar
adventurer
Originally Posted by PhillyEagleKGD
I did this last night and to me, it makes a very noticeable difference. It really smoothed-out my idle, and definitely helped with throttle response as well.I would highly recommend doing this "mod".
Good
, ur the first who gave feed back, i ll try it this weekend
Old 01-19-2012, 01:50 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Sh*t, can't hurt nuthin'. Since I have a CAI I can get to the TB without having to remove anything. I'll give it a shot this weekend and see what it does...
Quick Reply: grounding the TB ???
