Key Programming
Old 01-10-2012, 05:58 PM
dodgebear's Avatar
dodgebear
dodgebear is offline
Default Key Programming
Did anyone ever figure out how to program the key on the 2009 GC?
It was easy on my 2005 but have not found the skinny on this one.
Old 01-24-2012, 10:51 AM
vpnavy's Avatar
vpnavy
vpnavy is offline
Until someone pipes in - take a look at Smart key questions... - 05-25-2011, 10:37 PM .
Old 01-24-2012, 07:10 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
DodgeCaravan2010SXT is offline
i beleive if i remember how i did mine 2010 is u need 2 keys originals. u put in the first turn to the on but dont start then put other one in and do the same. then on the one u want to program u put it in and then start the vehicle. vehicle should start up with the third key. i have to look up the instructions, not sure where i put them right now.
Old 01-26-2012, 10:34 PM
georgef's Avatar
georgef
georgef is offline
I used the following procedure to program a third key for my 2009 Caravan (cut & pasted from the first edition 2009 Caravan pdf manual):
Customer Key Programming
If you have two valid RKE transmitters with integrated
keys, you can program new RKE transmitters to the
system by performing the following steps:
1. Insert the first valid integrated key into the ignition
switch and turn the ignition switch to the ON position for
at least three seconds, but no longer than 15 seconds.
Turn the ignition switch to the LOCK position and
remove the first key.
2. Insert the second valid integrated key and turn the
ignition switch to the ON position within 15 seconds.
After 10 seconds, a chime will sound and the Vehicle
Security Light will begin to flash. Turn the ignition switch
to the LOCK position and remove the second key.
3. Insert a blank integrated key into the ignition switch
and turn the ignition switch to the ON position within
60 seconds. After 10 seconds, a single chime will sound
and the Vehicle Security Light will stop flashing, turn the
ignition switch ON again for three seconds, and then turn
it OFF.
The new integrated key is programmed. The Remote
Keyless Entry (RKE) transmitter will also be programmed
during this procedure.
Repeat the above steps to program up to eight keys. If
you do not have a programmed RKE transmitter with
integrated key, contact your authorized for details.
There was something that didn't work exactly like the instructions, I think maybe there was no chime at step 2, but I can't remember for certain.
For some reason this section of the manual was removed from later editions of the manual.
George
Old 01-27-2012, 10:25 AM
dodgebear's Avatar
dodgebear
Many thanks for those who responded, very helpful.
Now where do I get a good price on a blank key? $75 semms too high!
Old 01-27-2012, 08:00 PM
DodgeCaravan2010SXT
got one from ebay remanufactored 50.00usd. now i know its used but ive bought one from this seller and it worked so now i need new and waiting on it.
Old 08-03-2017, 01:29 AM
magnavideo's Avatar
magnavideo
magnavideo is offline
Default Inexpensive Chip Key Source
2002 Caravan Sport.
I purchased the exact chip keys from www.remotesremotes.com on their eBay site store for $12.00/pair.
Then followed GEORGEF instructions in this thread. They work fine. Also, this site explains eve more: http://www.automotiveandcommerciallo...-instructions/
Don't waste your time and $$$ at the dealer.
Also, use these instructions for the remote key fob only: https://www.remotesremotes.com/Repla...ons-s/6647.htm
Old 08-03-2017, 08:23 AM
jkeaton is offline
This thread is 5 years old....
Quick Reply: Key Programming
