OEM security system
Old 01-10-2012, 05:54 PM
megatron96541's Avatar
megatron96541
megatron96541 is offline
Default OEM security system
I have a 99 durango. Today after work, I attempted to get in my truck from the passenger side. Open the door, reached for the glove box and all of a sudden my horn starts honking out of nowhere along with the red security light blinkinh off and on. Now, i had no clue that my durango had a security system on it. I dont have the factory key fob, rather a replacement key from wally world i would assume. So i tried starting the vehicle, it started then immediately shut off. Tried once more, same outcome. So i popped the hood open, pulled the negative cable, put it back on and it stopped. Went to attempt to start again, it honked twice really fast then i was able turn the durango on and make my way home withou lt any further problems.
Not sure how to diagnose this or know if this is a problem. Any help would great.
Old 01-10-2012, 06:19 PM
adukart's Avatar
adukart
adukart is offline
The quick honk is a indicator that the system was set off and you should check to see if anything is missing. Were the other doors locked and the passenger side didn't so when you opened it, it thought that someone broke in?
Old 01-10-2012, 06:27 PM
megatron96541
You know, i want to say that it was locked and i unlocked it with my key. But i cant say as i dont remember.
Old 01-11-2012, 11:31 AM
megatron96541
Any other guesses as to why it did this?
Old 01-11-2012, 12:32 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
im not going to lie i dont see how you would forget unlocking it sinc ei have never seen a durango with a keyhole in the passenger door, only in the drivers side and the liftgate, if you just walked up to the truck and opened the door you either unlocked it with the remote (doubtful since that would disable the alarm) it wasnt locked (doubtful since then the alarm wouldnt have been set) that door just never locked, or you unlocked it with the key from the drivers door and unlocked the passenger door from inside.
Old 01-11-2012, 01:33 PM
srch4me's Avatar
srch4me
srch4me is offline
actually the durango does have a keyhole on the passenger side front door. just not any of the rear doors. i just checked.
Old 01-11-2012, 01:35 PM
shrpshtr325
THE ULTI-MOD
mine does NOT have a keyhole in the passenger door, must have been on the base models in the first part of the run only then
Old 01-11-2012, 01:39 PM
srch4me's Avatar
srch4me
srch4me is offline
i believe you sharps. i just looked up pictures of the different years and it looks like 98 and 99 did have keyholes on the passenger side.. 2000 seems to be the year they made all the little changes. i know that if you unlock the car from the drivers side that it dissables the alarm, dont think doing the same from the passenger side does.
Old 01-11-2012, 01:44 PM
TurboStixx's Avatar
TurboStixx
TurboStixx is offline
hmm, my 99 has a keyhole as well. I know the feeling mega, my alarm likes to go off randomly when I unlock the drivers door with the key (I don't have the FOB either). Then again my security alarm is stupid, It likes to blink intermittently and doesn't ALWAYS turn off when I reset the alarm via drivers door with key. The Start-up/shut-down is the alarm system disabling the truck from moving.
next time (if it happens) shut the passenger door, go over to the drivers door and use the key to lock the truck then unlock it, it will reset the alarm.
Old 01-11-2012, 01:53 PM
adukart's Avatar
adukart
adukart is offline
I had to reset mine after the vice principal helped me break in after locking my keys in. I pulled the battery negative, locked all the doors by hand then reconnected the battery and used the key in the drivers door. Been working ever since.
Quick Reply: OEM security system
