set clock in a 93' ?
Old 12-27-2011, 07:12 PM
jnellydodge's Avatar
jnellydodge
jnellydodge is offline
Default set clock in a 93' ?
1993 dodge w-150. Embarrased to ask but how in the heck do you set the stock chrysler clock with the am/fm radio/cassette? There are no select, set, clock, or hour-minute buttons anywhere on the face. Have tried multiple button combinations and no luck. Thanks in advance.
Old 12-27-2011, 10:52 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
disconnect power and re hook it up at 12 O-clock.
JK. there should be 2 very tiny buttons right of the tape deck about the size of paper clips. one has H and the other has M above them and they should be what you have to use to set the time.
Old 12-28-2011, 07:53 AM
jnellydodge
Ha. I wish it were that easy, but as I said in my original post there are no hour- minute buttons anywhere on the face.
Old 12-28-2011, 08:43 AM
charlie1935's Avatar
charlie1935
charlie1935 is offline
On my 96 there is two little holes to the right of the tape slot.
The top one is the hour, bottom one minutes.
A ball point pen works fine.
Old 12-28-2011, 08:52 AM
SEAL's Avatar
SEAL
SEAL is offline
I have a factory manual on Chrysler Sound Systems. Everyone of the listed original equipment am/fm/cassette radios has a set button and all but one have select buttons. Are you sure it is the original radio? If you can show a picture of the face or list the buttons that are there instead of the ones that aren't there we might be able to help further.
Old 12-28-2011, 10:58 AM
jnellydodge
Thanks for the replies guys, I will take a pic of it this evening.
Old 12-28-2011, 04:34 PM
crazzywolfie
i am only able to find 2 types of tape deck stereos. both have the little tiny H and M somewhere to set the clock
this one has them on the display
this one has them right of the tape deck
Old 12-28-2011, 10:51 PM
jnellydodge
Picture not wanting to load, in the mean time here are the userrs button options:
Volume ****, Treble, Bass, Balance, Seek, Scan, pesets 1,2,3,4,5,6 Am/Fm button, Tune **** , Eject, and NR. THERE ARE NO HOUR MINUTE BUTTONS anywhere lol. Ive owned every generation ram out there so ive seen other setups such as the hour-minute buttons or the SEL-SET buttons which are easy to figure out but this damn radio in the 93' i cannot figure out haha.
Hope this helps I will try to figure out why my pics wont load when i get more time.
Old 12-28-2011, 11:11 PM
crazzywolfie
sounds like someone might have installed an older stock stereo in it.
is it one of these
http://www.allpar.com/stereo/Infinity/index.html
http://www.allpar.com/stereo/Infinity-II/index.html
Old 12-28-2011, 11:18 PM
NyghtProwler's Avatar
NyghtProwler
NyghtProwler is offline
after extensive research....like crazy did....sounds like the Factory Quartz lock System....
is this the one?
http://www.allpar.com/stereo/quartz-lock/index.html
Quick Reply: set clock in a 93' ?
