abs hydraulic circuit malfunction
Old 12-26-2011, 03:15 PM
stupidcarpenter's Avatar
stupidcarpenter
stupidcarpenter is offline
Default abs hydraulic circuit malfunction
I got a code "9 hydraulic pump circuit malfunction" Any ideas on what to look at for this.
Its a 02 grand caravan. Thanks in advance.
Old 12-26-2011, 10:31 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
PUMP CIRCUIT FAILURE
When Monitored: Ignition on. The CAB commands the pump on at 20 km/h (12 mph) to
check its operation, if the brake switch is not applied. If the brake is applied, the test will
run at 40 km/h (25 mph). The CAB monitors pump voltage every 7 milliseconds.
Set Condition: The DTC is stored when the CAB detects: 1) Improper voltage decay after
the pump was turned off. 2) Pump not energized by the CAB, but voltage is present for 3.5
seconds. 3) Pump is turned on by the CAB, but without sufficient voltage to operate it.
I've seen the harness rub through and get corroded down by the hydraulic unit bracket.
Old 12-26-2011, 11:20 PM
steak59's Avatar
steak59
steak59 is offline
Check wiring loom, especially on all the connectors from Fuse Box to ABS unit. Most of the time is one of the connectors corroded off.
If nothing found visually, you HAVE to check for power and ground at the ABS pump before u condemn the ABS unit.
75% of the time this is a Wiring problem instead of the ABS unit failure. Mainly pay attention under the Fuse box.
The wiring loom runs under the Battery, and you have to remove the battery and battery tray to gain access to check the ABS unit. I recommend you to remove battery, put it aside, and use a remote jump cable to power vehicle for testing.
Of course, check for blown/missing fuse.
Old 12-26-2011, 11:47 PM
steak59's Avatar
steak59
steak59 is offline
if nothing visual found, you HAVE to run the diagnostic tree for the code. The Pump cost $400 + 3 hrs of labors.
When Monitored and Set Condition:
POSSIBLE CAUSES
PUMP HARNESS DISCONNECTED
CAB - PUMP MOTOR RUNNING CONTINUOUSLY
ABS PUMP MOTOR INTERMITTENT DTC
GROUND CIRCUIT HIGH RESISTANCE
FUSED B(+) CIRCUIT OPEN
GROUND CIRCUIT OPEN
CAB - INTERNAL FAULT
CAB - SETTING FALSE CODE
TEST ACTION APPLICABILITY
1 Turn the ignition off.
Turn the ignition on.
Monitor the pump motor for continuous operation.
Is the pump motor running continuously?
All
Yes
! Replace the Controller Anti-Lock Brake in accordance with the
Service Information. The vehicle must be driven at 25 km/h (15
mph) to extinguish the ABS indicator.
Perform ABS VERIFICATION TEST - VER 1.
No
! Go To 2
2 Turn the ignition on.
With the DRBIII
t, read DTC’s.
With the DRBIII
t, erase DTC’s.
With the DRBIII
t, actuate the ABS pump motor.
Did the Pump Motor operate when actuated?
All
Yes
! Go To 3
No
! Go To 4
CAB)
3 Turn the ignition off.
Visually inspect the related wiring harness. Look for any chafed, pierced, pinched, or
partially broken wires.
Make sure the Pump Motor connecter is secure.
Visually inspect the related wire harness connectors. Look for broken, bent, pushed
out, or corroded terminals.
Refer to any Hotline letters or Technical Service Bulletins that may apply.
Were any problems found?
All
Yes
! Repair as necessary. The vehicle must be driven at 25 km/h (15
No
4 Check the short Wiring Harness between the ABS Pump and the CAB.
Check for disconnect and damage.
Is the harness disconnected or damaged?
All
Yes
! Reconnect or repair the Pump Harness as necessary.
No
! Go To 5
5 Turn the ignition off.
Disconnect the CAB connector.
Note: Check connector - Clean/repair as necessary.
Using a 12-volt test light connected to ground, check the Pump Motor Fused B+
circuit.
Does the test light illuminate brightly?
All
Yes
! Go To 6
No
! Repair the Fused B(+) circuit for an open. The vehicle must be
driven at 25 km/h (15 mph) to extinguish the ABS indicator.
6 Turn the ignition off.
Disconnect CAB Connector.
Measure the resistance of the CAB ground circuits.
Is the resistance below 1.0 ohm?
All
Yes
! Go To 7
No
! Repair the ground circuit for an open. The vehicle must be driven
44
BRAKES (CAB)
PUMP CIRCUIT FAILURE —
Continued
7 Make sure the Pump Motor connector is secure.
With the DRBIII
t, enable pump motor actuation.
NOTE: Pump motor will not operate, but voltage will be applied.
Measure the voltage drop across theABS ground circuit connection, with pump motor
actuation enabled.
Is the voltage below 0.1 volt?
All
Yes
! Go To 8
No
! Repair the Ground circuit for high resistance. The vehicle must be
8 If there are no possible causes remaining, view repair. All
Repair
Old 12-27-2011, 06:55 AM
stupidcarpenter
Thanks. Well, looks like I got some work to do.
Quick Reply: abs hydraulic circuit malfunction
