2011 Dodge Caravan Tire Pressure Monitoring Light
Old 12-20-2011, 09:15 PM
mrgto69's Avatar
mrgto69
mrgto69 is offline
Default 2011 Dodge Caravan Tire Pressure Monitoring Light
Guys, I am new to this forum and new to Mopar. I just purchased a 2011 Caravan and need some assistance. I have a TPML lit on my dash and I checked the service manual & DVD and it does not tell me how to reset this light. Can anyone tell me how to do this? Thanks in advance... Mike
Old 12-20-2011, 09:51 PM
steak59's Avatar
steak59
steak59 is offline
Fill all tire up to 40PSI, light will go away. and light will come on if any tire drops below 32 PSI.
Old 12-20-2011, 09:58 PM
mrgto69's Avatar
mrgto69
mrgto69 is offline
I normally don't ride with that much in the tires. It'll wear the center of the tire out. I'll try 35 psi in all 4 tires. Is there a manual way to reset the light? Thanks...
Old 12-20-2011, 10:22 PM
steak59's Avatar
steak59
steak59 is offline
You could ask the Dealership to drop the Tire Threshold for you so lights would go away at 32+ PSI.
However, The Placard recommendation on the Minivan is 36PSI, light won't go away unless you fill tire up to 38+ PSI.
On this Minivan, even if you ride with 40PSI all the time, it will still wear the outer edge first because this Van is so heavy on such a small tire. Just look at the sidewall at 40PSI, u can tell 36-40 PSI is not too much for your Van.
If you ride on around 30-35 PSI all the time, you will wear the outer edge a lot faster.
Old 01-15-2012, 06:20 AM
vpnavy's Avatar
vpnavy
vpnavy is offline
I normally don't ride with that much in the tires...
When I have had that problem (in other rides) - I would fill up the tires to 40PSI and then drop them back down to 35PSI - drive a few miles and problem solved.
Quick Reply: 2011 Dodge Caravan Tire Pressure Monitoring Light
