2000 durango cranks but wont start
Old 12-17-2011, 01:48 PM
capefive's Avatar
capefive
capefive is offline
Default 2000 durango cranks but wont start
hello all, i've been reading through these forums and can't find my issue so here goes.
changed plugs,wires and distributer about 2 mo's ago and truck ran great. about 1 month ago out of the blue my truck would crank but not start, if i crank for like 2 min's and hold my foot on gas the truck starts real hard and then runs like theyres no problem. a friend told me to change the battery, that didnt do it, changed tps and that didnt do it, cleaned iac and still no luck. 2000 durango 5.9l slt. sorry if this is long and rambling. also pulled plugs and they were all junked up so i changed them again and still same problem.it is starting to get a little cold here not sure if that has anything to do with it.....
Old 12-17-2011, 02:18 PM
that_guy's Avatar
that_guy
that_guy is offline
try checking the connections on the crankshaft position sensor
Old 12-17-2011, 02:41 PM
capefive's Avatar
capefive
capefive is offline
yikes ! that is not as easy as it sounds, is it ok to remove all that electrical tape, this thing is wrapped up tight i can barely get to it
Old 12-17-2011, 02:46 PM
that_guy's Avatar
that_guy
that_guy is offline
the connection for the ckp is towards the back on the top of the engine, it's not very difficult to get to. check to make sure it has good contact
Old 12-17-2011, 08:38 PM
TurboStixx's Avatar
TurboStixx
TurboStixx is offline
Electrical taped? Did you buy this truck used? If so, I hope they didn't cut the wires and splice them! Thats not horrible, but can cause you trouble down the road if they are just spliced, I would take the electrical tape off and take a look!
If that doesn't work, I plug up the OBD II scanner to the truck and see if any stored codes are on it.
Old 12-17-2011, 08:42 PM
Double D Mods's Avatar
Double D Mods
Double D Mods is offline
Former Vendor
change the crank sensor and your good to go
this happened to myself
truck was running great
next morning wouldnt start changed crank sensor
back on the road!
Old 12-18-2011, 12:07 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Well duh, you can't get a 1st generation Durango that is not used?????
Anyway,
Change the Crank sensor, and it also could be the pickup sensor under the distributor, as well as a coil, and also fuel pressure (fuel pump).
Old 12-18-2011, 08:03 AM
TurboStixx's Avatar
TurboStixx
Well he could have bought it new when they came out and has had it since :-P
Quick Reply: 2000 durango cranks but wont start
