01 Dodge Durango 4 wheel drive
Old 12-11-2011, 11:57 AM
badcoupe34's Avatar
badcoupe34
badcoupe34 is offline
Default 01 Dodge Durango 4 wheel drive
I have a 2001 Dodge Durango with electronic 4 wheel drive. It won't engage at all. Can anyone point me in the right direction to diagnose the problem?
Old 12-11-2011, 12:09 PM
huseman808's Avatar
huseman808
huseman808 is offline
does your switch light up 4wd when you switch it? you should hear a clicking noise when it engages.
Old 12-11-2011, 01:22 PM
badcoupe34's Avatar
badcoupe34
No, I do not get even a light on the dash switch and no clunking or clicking whatsoever. I checked the fuse under the hood and it is ok. Switch maybe?
Old 12-11-2011, 01:56 PM
huseman808's Avatar
huseman808
Thats where I would start. Maybe go to a local junkyard and see if they have one that you could try in place of yours.
Old 12-11-2011, 03:27 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Check fuse 11 in the junction block, under the dash. It controls the status lights on the transfer case.
Quick Reply: 01 Dodge Durango 4 wheel drive
