33 12.50 15 on Stock Durango
Old 12-08-2011, 01:08 PM
Jordan91ulbrich's Avatar
Jordan91ulbrich
Jordan91ulbrich is offline
Default 33 12.50 15 on Stock Durango
Will 33 12.50 15's fit on a stock no lift 1998 dodge durango.
Thanks Jordan
Old 12-08-2011, 01:27 PM
ZCR1's Avatar
ZCR1
ZCR1 is offline
If you want to do some bodywork/trimming. Other than that 31/10.5/15's are max without some sort of lift.
Old 12-08-2011, 05:46 PM
adukart's Avatar
adukart
adukart is offline
Go ahead and search the t/s lift here, its cheap and will allow you to fit 33x12.50 with less trimming/rubbing. Or you can do a 3in body lift.
Old 12-08-2011, 06:22 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
to fit 33s properly without rubbing you need the 2" t/s lift and a 3" body lift
Old 12-08-2011, 06:24 PM
lvphotos's Avatar
lvphotos
lvphotos is offline
33x12.5x15 stock cranked up torsions.
Torsions maxed and a lot of rubbing. Go 33x10.50 or stick with 31 or 32s. BFG has this size in M/T and A/T. The 12.5 is too wide on stock rims, with offset rims it made it worse. Frame rubbing with stock 15x8 and outside with offset. Forklift test.
5.5" Tuff Country with 33x12.5x15 No body lift.
35x12.5x15 with Glassworks fenders 5.5TC lift. No body lift.
Most tire stores will test fit the tire for you. I tested size without adjusting torsions then they let me crank away. You will rub rear flares, I cut mine flush to door. Rub em till you get a good contact patch and trim till its gone. Flare is inch from metal. Front facia is easy to clearance, rear of stock front fenders can be worked without much being in the way. Get a good test of contact and trim little by little.
Old 12-08-2011, 07:13 PM
adukart's Avatar
adukart
adukart is offline
Yeah the best bet is do the t/s with body lift.
Old 01-01-2012, 06:35 PM
DodgeMan77's Avatar
DodgeMan77
DodgeMan77 is offline
Default Tire size help!!
I have a stock 1998 Durango 4x4 with maxed out torsion keys. Will 32x11.5x15 or 33x10.5x15 BFG MUD TERRAIN T/A KM2 tires fit with no rubbing?
Old 01-01-2012, 07:26 PM
TurboStixx's Avatar
TurboStixx
TurboStixx is offline
Without trimming or a T/S lift, from what was said earlier, no.
Old 01-01-2012, 08:22 PM
adukart's Avatar
adukart
adukart is offline
With the torsions maxed out like he does 32x10.50 no rubbing, 33x10.50 with possible rubbing.
Old 01-01-2012, 08:31 PM
Duranged408's Avatar
Duranged408
Duranged408 is offline
I love how all these people just go ball crazy on their torsion bars and run around telling everyone its the thing to do.. I would never crank past 8 full turns from stock, its like throwing money down the drain to be the badass in the mall parking lot .
Quick Reply: 33 12.50 15 on Stock Durango
