Old 08-05-2015, 07:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
how to remove a dakota back window?
Old 12-04-2011, 06:48 PM
mgaither0's Avatar
mgaither0
mgaither0 is offline
Default how to remove a dakota back window?
Well I've removed windows on hard tops for jeeps before but I've never replaced the entire frame and window on anything. I'm trying to figure out how to remove the frame and windows for the rear window on a 2nd generation dakota. What I read said about pealing thr weather stripping back. But I'm lost. How do I remove the window and frame? Thanks
Old 12-04-2011, 11:09 PM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
I've never done it(I think its pretty simple) you need to remove the weather stripping then there is like 6 metal tabs that hold the window to the cab. You need to bend those up and might even have to get a long blade to break the seal of the glue that holds your window in.
Old 12-05-2011, 12:13 AM
mgaither0's Avatar
mgaither0
so u believe that i remove the outside weather stripping and then work from there. I will have to check it out. It was giving me a bitch of a time today I know that.
Old 12-05-2011, 10:09 AM
dodgeramguy85
I've heard cut the weather stripping and then push out from the inside. But with how much glue there is holding the window in you need to get some sort of knife to cut the glue. Its not a simple job you can break the glass easily. Depending on what your problem is My insurance covered my rear window.
Old 12-05-2011, 12:44 PM
mgaither0's Avatar
mgaither0
My problem is the dumb *** red necks that owned the truck before me broke the back window so they took a sliding rear window off a ranger I believe and made it fit. Where it was to small they used duck tape. So I want it to not look like ****
Old 12-06-2011, 11:02 AM
dodgeramguy85
Well since your not going to reuse the window then you dont have to be to gentle with it. Just work your way around with a screw driver prying a little bit on it. Im sure if they half *** the window they prob didnt use actual window glue.
Old 12-27-2011, 12:25 AM
mgaither0's Avatar
mgaither0
but I'm trying to put a sliding rear back window in and a sliding back window you have to get the frame and all out also. Its not a window and weather stripping. You have to get the frame also.
Old 12-27-2011, 12:36 AM
dodgeramguy85
Im saying taking the old window out you can pry and not worry about messing it up. The one you are going to get from a yard or whereever you will have to just take a bunch of tools and see what you can do. You can find a yard that will pull the window for you too. Prob a little bit more cash but you dont have to really worry about trying to get it out. I have my old window from my truck in my garage. It was removed from safelite but doesnt look to easy.
Old 12-27-2011, 10:55 AM
JBs DAK's Avatar
JBs DAK
JBs DAK is offline
It's all one piece. The frame and the window are molded together.
Your not gonna be able to save the frame or the weather stripping.
When you buy your next window,.. It's gotta be new. It's next to
impossible to remove the window on our trucks without messing
up the weather stripping. I know, I've done it. It's not like the front
glass or other rear windows like on ford pick ups or chebbys.
Old 12-27-2011, 11:54 AM
dodgeramguy85
They saved mine and you don't have to use a brand new window.
Quick Reply: how to remove a dakota back window?
