band adjustment 46re
Old 11-26-2011, 12:21 PM
mj23polaris's Avatar
mj23polaris
mj23polaris is offline
Default band adjustment 46re
whats gotta be done, the trans is slipping and has been so i figure its not anything major or it would have died by now, so what are the torque specs on the bands?
Old 11-26-2011, 12:31 PM
Crank the adjuster screws it to 72 INCH pounds, and then back them off some specified number of turns. Spec for that should be in the service manual.
Old 11-26-2011, 12:36 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Some one needs a Haynes and to download the free FSM. https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old 11-26-2011, 12:40 PM
mj23polaris
i got the manual but i forgot it at home haha im at my buddies house about 15mins away and dont wanna burn the gas to drive back home to get it
Old 11-26-2011, 12:43 PM
BigBlue83's Avatar
BigBlue83
BigBlue83 is offline
I have the manual on me what yr is ur truck
Old 11-26-2011, 12:55 PM
zman17's Avatar
zman17
zman17 is offline
Do like HeyYou says and back off 2 turns. IIRC, that is what MonteC suggests.I could be wrong, Do a search or go get the manual, because I don't want to be responsible for your tranny blowing up.
Old 11-26-2011, 01:00 PM
zman17's Avatar
zman17
zman17 is offline
As far as the manual goes, back off front band 2 7/8 turns. Back band 2 turns.
Old 11-26-2011, 01:33 PM
mj23polaris
its 2001
Old 11-26-2011, 02:21 PM
mj23polaris
FRONT BAND
The front (kickdown) band adjusting screw is
located on the left side of the transmission case
above the manual valve and throttle valve levers.
(1) Raise vehicle.
(2) Loosen band adjusting screw locknut (Fig. 73).
Then back locknut off 3-5 turns. Be sure adjusting
screw turns freely in case. Apply lubricant to screw
threads if necessary.
(3) Tighten band adjusting screw to 8 N·m (72 in.
lbs.) torque with Inch Pound Torque Wrench
C-3380-A, a 3-in. extension and an appropriate
Torx™ socket.
CAUTION: If Adapter C-3705 is needed to reach the
adjusting screw, tighten the screw to only 5 N·m
(47-50 in. lbs.) torque.
(4) Back off front band adjusting screw 2-7/8
turns.
(5) Hold adjuster screw in position and tighten
locknut to 41 N·m (30 ft. lbs.) torque.
(6) Lower vehicle.
so i loosen the nut, i tighten the torque head to 72lbs then back the nut off again then tighten the the torque head again another 30lbs? jus wanna make sure i do this RIGHT haha
REAR BAND
The transmission oil pan must be removed for
access to the rear band adjusting screw.
(1) Raise vehicle.
(2) Remove transmission oil pan and drain fluid.
(3) Loosen band adjusting screw locknut 5-6 turns.
Be sure adjusting screw turns freely in lever.
(4) Tighten adjusting screw to 8 N·m (72 in. lbs.)
torque (Fig. 74).
(5) Back off adjusting screw 2 turns.
(6) Hold adjusting screw in place and tighten locknut
to 34 N·m (25 ft. lbs.) torque.
(7) Position new gasket on oil pan and install pan
on transmission. Tighten pan bolts to 17 N·m (13 ft.
lbs.) torque.
(8) Lower vehicle and refill transmission with
Mopart ATF +4, Type 9602 fluid.
so same here losen the nut tighten the torque head to 72lbs, then back the nut off hold it and tighten the torque head to 25lbs
any idea what torque bit it is?
Old 11-27-2011, 11:51 AM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
Originally Posted by mj23polaris
FRONT BAND
(1) Raise vehicle.
Torx™ socket.
turns.
(6) Lower vehicle.
REAR BAND
(1) Raise vehicle.
torque (Fig. 74).
lbs.) torque.
it a TORX bit...sometimes called a star bit.... Chrysler /jeep dodge has been using them for over a decade now....
I'm adjusting my bands today also to eliminat any of the easy stuff before taking it to a shop where the answer is almost always "You need a rebuild".
Quick Reply: band adjustment 46re
