Fluid Capacities File
Old 11-25-2011, 02:37 PM
TurboStixx's Avatar
TurboStixx
TurboStixx is offline
Default Fluid Capacities File
I used my time at work today for some good at least!
I took Master Techs Fluid Capacity Forum Post that is in the DIY thread and turned it into an easy to read PDF table. Take a look.
Old 11-25-2011, 05:52 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Very nice job.
Old 11-25-2011, 05:57 PM
TurboStixx's Avatar
TurboStixx
Thanks tech, don't want to steal your table, but I was bored at work with access to tools to make it, so I decided to do it and transfer it all to quarts
Old 11-25-2011, 06:03 PM
master tech
Don't worry. Eveything I post is for all of the members to use.
Old 11-25-2011, 06:13 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
nice table, i see just one error, you have the 4.7 listed as a v6, its not the 4.7 is a v8
Old 11-25-2011, 07:26 PM
TurboStixx's Avatar
TurboStixx
Not exactly sure why I did that, I will correct tomorrow and upload a new one!
Old 11-26-2011, 05:20 PM
Dirtrango's Avatar
Dirtrango
Dirtrango is offline
My question is. Are the numbers for the 5.9 the same for the 5.2??? I ask because there is no mention of the 5.2...
Also you have the numbers a little mixed up.
Specifications Fluid Capacity-with new Filter
4.7L V6 6.0 Quarts (5.7L)
5.9L V8 5.0 Quarts (4.7L)
when you fix it you should swap the capacities to reflect what is across from the spec's. unless the 4.7 takes 1qrt more the the 5.9?
Old 11-26-2011, 05:21 PM
TurboStixx's Avatar
TurboStixx
No Clue Dirt, BUT! I am making a Specifications/Sensor Location PDF as we speak for the 5.1, since i have the 5.2. Though I am showing on a 5.2 A service Tranny fluid fill is only 1.5 quarts. This can't be right!
Old 11-26-2011, 05:47 PM
Compactc9's Avatar
Compactc9
Compactc9 is offline
I know the 4.7 does take about that much more than the 5.2, no clue on a 5.9
Old 11-26-2011, 05:56 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
This is correct, all in all the transmission only holds a total of 6 quarts in it (not including the lines of course)... Here this is straight from Chrysler TechConnect:
Quick Reply: Fluid Capacities File
