trouble w/ fuel gauge. full empty no wait full again
95 ram 2500 w/ 5.9 fuel gauge has always worked untill recently. over the past week it start fluctuating up and down alot, maybe once reading below empty w/ fuel light on even tho tank was full.
past 2 days gauge has not come up above empty and fuel light has not gone out.
where do I start?
did a search and found people saying it was in the FAQ so I looked there and could not find anything.
thank you
where do I start?
thank you
Seems like your sending unit has gone bad. My 95 did the same thing to the point of using the trip odometer to judge the remaining fuel. I used this method until the fuel pump went bad and I had the replace the fuel pump module and it was back to normal. From what I have read some fuel blends leave a residue on the wiper arm of the sending unit and it starts out with erratic readings and finally just quits.
