What size socket for front axle nut?
Old 11-20-2011, 03:28 PM
Hans_GZP's Avatar
Hans_GZP
Hans_GZP is offline
Default What size socket for front axle nut?
On my 96 ram 2500 4x4 with a Dana 60 front axle. What is the nut size for the axle. I just had the bearing go out on me and I'm 200 miles from home. Need to do a road side repair.
Old 11-20-2011, 03:29 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
1 11/16 or 43mm IIRC
Old 11-20-2011, 03:42 PM
Hans_GZP's Avatar
Hans_GZP
Hans_GZP is offline
Thanks!!!
Old 11-20-2011, 03:43 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
No problem. Hope you get it all fixed up!
Edit: Dont forget to get it all torqued back to spec or else you will be replacing it sooner than you want to be.
Old 11-20-2011, 03:51 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
+1.... get a Haynes or download the FSM . Torque specs on all projects are very important.
Old 11-20-2011, 03:55 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
zman i found this on another site but is this the correct steps for the dana 60? Reason I ask is because a friend of mine has one that I will be helping him with. Thanks
FRONT wheel-bearing adjuster (inner)nut:
Step 1: To seat, torque nut to 50(lb-ft) while spinning hub.
Step 2: Back off, then torque to 35(lb-ft) for automatic hubs,or 50(lb-ft) for manual hubs.
Step 3: Back off 3/8-turn for automatic hubs, and just enough to free the bearing for manual hubs.
Front wheel bearing lock (outer) nut- 160 (lb-ft
Old 11-20-2011, 04:16 PM
zman17's Avatar
zman17
zman17 is offline
Although it can't hurt to do that procedure (I think that's for a 2wd) All you need to do is install the hub. Tighten the 3 bolts to 125 foot pounds and the tighten the axle nut to 175 foot pounds.
Old 11-20-2011, 04:22 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Alright thats good to know
Old 11-20-2011, 04:54 PM
Hans_GZP's Avatar
Hans_GZP
Hans_GZP is offline
Mine is a 4 bolt pattern. No torque wrench with me. But I have my own measurement of torque when it comes to bolts going that right. It's called goodandtightnow.
Old 11-20-2011, 05:01 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Thats usually the way I do it!!! but if its other peoples stuff I make sure and get it done correctly.
Quick Reply: What size socket for front axle nut?
