2004 Dodge Ram 2500 Diesel Shifting problems
Old 11-17-2011, 07:26 PM
kraab_13's Avatar
kraab_13
kraab_13 is offline
Default 2004 Dodge Ram 2500 Diesel Shifting problems
I have a 2004 dodge ram 2500 turbo diesel automatic that has just started experiencing shifting problems. I bought the truck when it had 60k miles on it, it now has 116,000. The truck tows a 7x16 trailer with a couple mowers often, as well as some snow plowing in the winter.
The problem seems to be shifting out of 1st gear. Out of the blue it started to act up...It doesn't want to shift into second gear, when it warms up however it will shift into 2nd gear but at a higher RPM than usual (2500rpm +) I don't known if it has trouble getting from 2nd to 3rd, Im afraid to take it out on the highway and its hard to get up to that speed on the road in my town. Sometimes it will shift in to 2nd gear when I completely let off of the accelerator.
To be honest, I think the tranny fluid has only been changed once. Im taking it in tomorrow to hopefully get figured out and fixed but I wanted to see what yall thought. I did a lot of research about this problem and it seems to be a problem for a lot of people but if anyone else can shed some light on this Id appreciate it greatly. Hopefully there isn't anything wrong mechanically with the trans, hopefully its electronic or something simple.
Old 12-06-2011, 09:19 PM
jonathan39073's Avatar
jonathan39073
jonathan39073 is offline
having the same problem, have you found out what it was?
Old 12-06-2011, 10:52 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
BrianSudokhoi02 is offline
Have you changed transmission fluid/filter and adjusted the bands? Changing/adjusting these things first would be where I would start. You are supposed to be doing this stuff every 30k.
Old 12-07-2011, 08:13 AM
kraab_13's Avatar
kraab_13
kraab_13 is offline
The problem with mine was the governor pressure solenoid and pressure sensor. It's a really easy fix I found directions on fixing it on here somewhere.
After replacing those two things, the truck shifts great.
Old 12-08-2011, 05:45 PM
(texas-ram)325HP's Avatar
(texas-ram)325HP
(texas-ram)325HP is offline
Ill stick to my manual never liked automatics really lol
Old 07-27-2020, 06:39 PM
Gregory Bourquin's Avatar
Gregory Bourquin
Gregory Bourquin is offline
Default Tranny fixed as mentioned. 4 days later now having problems trshnfting into high gear
[QUOTE=kraab_13;2662166]The problem with mine was the governor pressure solenoid and pressure sensor. It's a really easy fix I found directions on fixing it on here somewhere.
After replacing those two things, the truck shifts great.[/QUOTshift when acceleration is about 50
Quick Reply: 2004 Dodge Ram 2500 Diesel Shifting problems
