Old 08-05-2015, 07:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
How to replace driver side mirror on 98??
Old 07-29-2005, 01:03 AM
NLucas's Avatar
NLucas
NLucas is offline
Default How to replace driver side mirror on 98??
Help! I need to replace the drivers side mirror on my 98 Stratus... Can anyone tell me how to do this? I have no clue where to even start... Thanks so much!!!
Nicole [sm=helpout.gif]
Old 07-29-2005, 05:04 PM
Brock0295's Avatar
Brock0295
Brock0295 is offline
Default RE: How to replace driver side mirror on 98??
start by taking off the plastic thing on the inside of your your there the mirror is there should be bolts there
Old 07-30-2005, 03:13 AM
stratusfear23's Avatar
stratusfear23
stratusfear23 is offline
You have to remove the door panel to access the bottom screw on panel for the mirror
There is a small screw that holds that triangle panal on, once you take that off there are 3 screws and a wire harness that connect the mirror
Hope this helps and sorry that the picture is so big.
Old 08-13-2005, 10:04 PM
mariofleal's Avatar
mariofleal
mariofleal is offline
I just try to replce the passenger mirror and 1 of the 3 bolts can not be reached by only taking off the plastic cover. What is the next step? Should I take off the door panel? How can I take off the door panel?
Quick Reply: How to replace driver side mirror on 98??
