Ground G207 location?
Old 11-09-2011, 09:46 PM
WyzGuy's Avatar
WyzGuy
WyzGuy is offline
Default Ground G207 location?
Tracking down my service 4wd light issue...points to this ground point. Anyone know exactly WERE it is?
2001 Durango
Old 11-09-2011, 10:36 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
DESCRIPTION
This section provides illustrations identifying component and connector locations in the vehicle. A connector index is provided. Use the wiring diagrams in each section for connector identification. Refer to the index for the proper figure number. For items that are not shown in this section N/S is placed in the Fig. column.
Connector Name/Number Color Location Fig.
A/C Compressor Clutch BK Side of A/C Compressor, Rear of A/C Compressor (ENGINE LEFT SIDE 5.9L), (ENGINE RIGHT SIDE 4.7L)
A/C Heater Control - C1 BK At HVAC Control (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
A/C Heater Control - C2 BK At HVAC Control (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
A/C Heater Control - C3 BK At HVAC Control (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
A/C Heater Control - C4 BK At HVAC Control (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
A/C Low Pressure Switch GN Right Rear of Engine Compartment (RIGHT REAR ENGINE COMPARTMENT), (RIGHT REAR ENGINE COMPARTMENT CONNECTORS)
A/C Pressure Transducer BK Right Fender Side Shield N/S
Airbag Control Module YL Lower Center of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS), (AIRBAG CONTROL MODULE)
Ambient Temperature Sensor BK Radiator Top Support (RIGHT FRONT ENGINE COMPARTMENT)
Amplifier-C1 WT Right Side of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Amplifier-C2 WT Right Side of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Automatic Day/Night Mirror BK Top of Windshield (OVERHEAD CONNECTORS)
Battery Temperature Sensor BK At Battery (LEFT FRONT ENGINE COMPARTMENT)
Blower Motor BK Upper Center of Instrument Panel N/S
Blower Motor Resistor Block BK Upper Center of Instrument Panel N/S
Brake Lamp Switch BK Lower Left of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS)
Brake Pressure Switch BK At Anti-Lock Brake Controller (RIGHT FENDER AREA)
C105 BK Right Fender Side Shield at the Power Distribution Center (RIGHT FRONT ENGINE COMPARTMENT), (RIGHT REAR ENGINE COMPARTMENT), (RIGHT REAR ENGINE COMPARTMENT CONNECTORS)
C106 NAT Right Fender Side Shield at the Power Distribution Center N/S
C107 (4.7L) Left Fender Side Shield N/S
C126 BL Lower Left of Instrument Panel (KICK PANEL AREAS)
C129 Rear of Transmission (AUTOMATIC TRANSMISSION 4.7L (4X2) (EXCEPT CALIFORNIA))
C200 BK Lower Left of Instrument Panel (KICK PANEL AREAS), (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
C201 Right Side of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS), (BODY WIRING)
C202 Upper Center of Instrument Cluster (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
C246 Lower Left of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (BODY WIRING)
C247 Lower Left of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS), (BODY WIRING)
C248 BK Under Driver Seat (BODY WIRING)
C249 BK Under Passenger Seat (BODY WIRING)
C301 (Base) BK Between Front Seats (BODY WIRING)
C302 (Premium) Between Front Seats (BODY WIRING)
C325 BK Top Center of Liftgate (LIFTGATE CONNECTORS)
C326 BK Top Center of Liftgate (LIFTGATE CONNECTORS)
C333 BK Left Rear Frame (TRAILER TOW CONNECTOR)
C341 BK Trailer Tow Wiring (TRAILER TOW CONNECTOR)
C349 At Right D-Pillar (TAIL LAMP AREA)
C352 BK Near Frame Ground Left Fender (LEFT FENDER AREA), (CHASSIS WIRING)
C360 BK Left Inner Fender N/S
C361 NAT Near Right Front Door Hinge (BODY WIRING)
C362 BK Near Right Front Door Hinge (BODY WIRING)
C363 BK Near Left Front Door Hinge (BODY WIRING)
C364 NAT Near Left Front Door Hinge (BODY WIRING)
C365 BK Near Left Rear Door Hinge (BODY WIRING)
C366 BK Near Right Rear Door Hinge (BODY WIRING)
C401 NAT Top Center of Liftgate (LIFTGATE CONNECTORS)
Camshaft Position Sensor GY At Distributor, Right Front of Engine (REAR ENGINE, 5.9L), (ENGINE CONNECTORS FRONT 4.7L)
Capacitor BK Left Side of Engine (RIGHT REAR ENGINE COMPARTMENT CONNECTORS)
Center Console Lamp In Center of Console N/S
Center High Mounted Stop Lamp No. 1 BK Headliner N/S
Center High Mounted Stop Lamp No. 2 BK Headliner N/S
Center High Mounted Stop Lamp No. 3 BK Headliner N/S
Center Power Outlet In Center of Console N/S
Central Timer Module-C1 Left Side of Instrument Panel (INSTRUMENT PANEL CONNECTORS)
Central Timer Module-C2 Left Side of Instrument Panel (BODY WIRING)
Central Timer Module-C3 GY Left Side of Instrument Panel (KICK PANEL AREAS)
Cigar Lighter NAT Upper Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
Clockspring-C1 Steering Column (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (MULTI-FUNCTION SWITCH CONNECTORS)
Clockspring-C2 Steering Column (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (MULTI-FUNCTION SWITCH CONNECTORS)
Clockspring-C3 BK Steering Column N/S
Clockspring-C4 Steering Column N/S
Coil On Plug No.1 BK Left Side of Engine (ENGINE LEFT SIDE 4.7L)
Coil On Plug No.2 BK Right Side of Engine (ENGINE RIGHT SIDE 4.7L)
Coil On Plug No.3 BK Left Side of Engine (ENGINE LEFT SIDE 4.7L)
Coil On Plug No.4 BK Right Side of Engine (ENGINE RIGHT SIDE 4.7L)
Coil On Plug No.5 BK Left Side of Engine (ENGINE LEFT SIDE 4.7L)
Coil On Plug No.6 BK Right Side of Engine (ENGINE RIGHT SIDE 4.7L)
Coil On Plug No.7 BK Left Side of Engine (ENGINE LEFT SIDE 4.7L)
Coil On Plug No.8 BK Right Side of Engine (ENGINE RIGHT SIDE 4.7L)
Combination Flasher BK Lower Left Side of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Controller Antilock Brake-C1 BK At Antilock Brake Controller (RIGHT FENDER AREA)
Controller Antilock Brake-C2 BK At Antilock Brake Controller (RIGHT FENDER AREA)
Crankshaft Position Sensor (4.7L) BK Rear of Engine (ENGINE RIGHT SIDE 4.7L)
Crankshaft Position Sensor (5.9L) BK Rear of Engine (REAR ENGINE, 5.9L)
Data Link Connector BK Lower Left of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Diagnostic Junction Port BK Lower Left of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Driver Airbag YL Steering Column N/S
Driver Blend Door Actuator Left Side of Instrument Panel N/S
Driver Cylinder Lock Switch BK Driver Door (FRONT DOOR CONNECTORS)
Driver Door Module-C1 BL Driver Door (FRONT DOOR CONNECTORS)
Driver Door Module-C2 BL Driver Door (FRONT DOOR CONNECTORS)
Driver Door Power Lock Motor/Ajar Switch BK Driver Door (FRONT DOOR CONNECTORS)
Driver Door Power Window Motor BK Driver Door (FRONT DOOR CONNECTORS)
Driver Heated Seat Under Driver Seat (BODY WIRING)
Driver Heated Seat Switch RD Under Driver Seat N/S
Driver Power Lumbar Motor Under Driver Seat N/S
Driver Power Mirror Driver Door (FRONT DOOR CONNECTORS)
Driver Power Seat Motors Under Driver Seat N/S
Driver Power Seat Switch Under Driver Seat N/S
Driver Seatbelt Tensioner Pillar Between Driver Doors (BODY WIRING)
Duty Cycle Evap/Purge Solenoid GY Rear of Engine Compartment (LEFT FRONT ENGINE COMPARTMENT), (RIGHT REAR ENGINE COMPARTMENT), (RIGHT REAR ENGINE COMPARTMENT CONNECTORS)
Engine Coolant Temperature Sensor (5.9L) BK At Thermostat Housing N/S
Engine Coolant Temperature Sensor (4.7L) BK At Thermostat Housing (ENGINE CONNECTORS FRONT 4.7L)
Engine Oil Pressure Sensor BK Right Front of Engine (REAR ENGINE, 5.9L), (ENGINE LEFT SIDE 4.7L)
Evaporator Temperature Sensor BK Upper Center of Instrument Cluster N/S
Front Dome Lamp BK Center Above Windshield (OVERHEAD CONNECTORS)
Front Washer Pump Motor BK At Washer Fluid Reservoir (RIGHT FRONT ENGINE COMPARTMENT)
Front Wiper Motor BK At Motor (LEFT FENDER AREA)
Fuel Injector No. 1 BK At Injector (ENGINE LEFT SIDE 5.9L), (ENGINE LEFT SIDE 4.7L)
Fuel Injector No. 2 BK At Injector (ENGINE RIGHT SIDE 5.9L), (ENGINE RIGHT SIDE 4.7L)
Fuel Injector No. 3 BK At Injector (ENGINE LEFT SIDE 5.9L), (ENGINE LEFT SIDE 4.7L)
Fuel Injector No. 4 BK At Injector (ENGINE RIGHT SIDE 5.9L), (ENGINE RIGHT SIDE 4.7L)
Fuel Injector No. 5 BK At Injector (ENGINE LEFT SIDE 5.9L), (ENGINE LEFT SIDE 4.7L)
Fuel Injector No. 6 BK At Injector (ENGINE RIGHT SIDE 5.9L), (ENGINE RIGHT SIDE 4.7L)
Fuel Injector No. 7 BK At Injector (ENGINE LEFT SIDE 5.9L), (ENGINE LEFT SIDE 4.7L)
Fuel Injector No. 8 BK At Injector (ENGINE RIGHT SIDE 5.9L), (ENGINE RIGHT SIDE 4.7L)
Fuel Pump Module LTGY At Fuel Tank (CHASSIS WIRING)
G100 Right Front of Engine Compartment (RIGHT REAR ENGINE COMPARTMENT)
G102 Left Inner Fender (LEFT FENDER AREA)
G105 Top Rear of Valve Cover, Right Front of Engine (ENGINE CONNECTORS FRONT 4.7L)
G110 Left Front Inner Fender N/S
G111 Engine Ground (ENGINE LEFT SIDE 5.9L), (ENGINE LEFT SIDE 4.7L)
G112 Right Fender Side Shield (RIGHT FRONT ENGINE COMPARTMENT)
G113 Near Battery (LEFT FRONT ENGINE COMPARTMENT)
G115 Right Fender Side Shield (RIGHT REAR ENGINE COMPARTMENT), (RIGHT REAR ENGINE COMPARTMENT CONNECTORS)
G201 Lower Center of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS), (AIRBAG CONTROL MODULE)
G205 Right Side Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
G207 Lower Center of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS), (AIRBAG CONTROL MODULE)
G208 Right Side Instrument Panel (INSTRUMENT PANEL CONNECTORS)
G304 Left Rear Body Ground (REAR BODY WIRING)
G305 Frame Ground Left Fender (LEFT FENDER AREA), (CHASSIS WIRING)
G306 Left Rear Body Ground (REAR BODY WIRING)
G307 Near T/O to Seatbelt Switch (BODY WIRING)
Generator BK At Generator (ENGINE RIGHT SIDE 5.9L), (ENGINE LEFT SIDE 4.7L)
Glove Box Lamp and Switch BK Upper Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Headlamp Switch BK Left Side of Instrument Panel (LEFT SIDE INSTRUMENT PANEL CONNECTORS)
Heated Seat Module GN Between Front Seats N/S
High Note Horn BK Left Front Inner Fender (RIGHT FRONT ENGINE COMPARTMENT)
Idle Air Control Motor (5.9L) BK At Throttle Body (ENGINE LEFT SIDE 5.9L)
Idle Air Control Motor (4.7L) GY At Throttle Body (ENGINE LEFT SIDE 4.7L)
Ignition Coil LT GY Near Distributor, Right Front of Engine (ENGINE RIGHT SIDE 5.9L)
Ignition Switch BK Steering Column (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (MULTI-FUNCTION SWITCH CONNECTORS)
Input Speed Sensor Left Side of Transmission (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (EXCEPT CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (EXCEPT CALIFORNIA))
Instrument Cluster-C1 GY At Instrument Cluster (LEFT SIDE INSTRUMENT PANEL CONNECTORS)
Instrument Cluster-C2 BK At Instrument Cluster (LEFT SIDE INSTRUMENT PANEL CONNECTORS)
Intake Air Temperature Sensor GY At Throttle Body, Right Top of Intake Manifold (ENGINE RIGHT SIDE 5.9L), (ENGINE LEFT SIDE 4.7L)
Joint Connector No. 1 Power Distribution Center N/S
Joint Connector No. 2 Power Distribution Center N/S
Joint Connector No. 3 Left Side Instrument Panel N/S
Joint Connector No. 4 Near Steering Column (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Junction Block-C1 At Junction Block (KICK PANEL AREAS)
Junction Block-C2 At Junction Block (KICK PANEL AREAS)
Junction Block-C3 At Junction Block N/S
Junction Block-C4 At Junction Block (BODY WIRING)
Junction Block-C5 At Junction Block (BODY WIRING)
Junction Block-C6 GN At Junction Block (JUNCTION BLOCK CONNECTORS)
Junction Block-C7 BK At Junction Block (JUNCTION BLOCK CONNECTORS)
Junction Block-C8 BR At Junction Block (JUNCTION BLOCK CONNECTORS)
Junction Block-C9 BL At Junction Block (JUNCTION BLOCK CONNECTORS)
Junction Block-C10 LTGY At Junction Block (JUNCTION BLOCK CONNECTORS)
Junction Block-C11 At Junction Block (JUNCTION BLOCK CONNECTORS)
Junction Block-C12 OR At Junction Block (JUNCTION BLOCK CONNECTORS)
Leak Detection Pump BK Near Battery (LEFT FRONT ENGINE COMPARTMENT), (RIGHT FENDER AREA)
Left Fog Lamp WT At Lamp (RIGHT FRONT ENGINE COMPARTMENT)
Left Front Door Tweeter NAT Left Door (FRONT DOOR CONNECTORS)
Left Front Door Woofer Left Door (FRONT DOOR CONNECTORS)
Left Front Park/Turn Signal Lamp No.1 BK At Lamp N/S
Left Front Park/Turn Signal Lamp No.2 BK At Lamp N/S
Left Front Side Marker Lamp At Lamp N/S
Left Front Wheel Speed Sensor LT GY Near Brake Controller (LEFT FRONT ENGINE COMPARTMENT), (RIGHT FENDER AREA)
Left Headlamp BL At Lamp N/S
Left Rear Door Power Lock Motor/Ajar Switch BK Rear Door (REAR DOOR CONNECTORS)
Left Rear Door Power Window Motor BK Left Door (REAR DOOR CONNECTORS)
Left Rear Door Power Window Switch BL Left Door (REAR DOOR CONNECTORS)
Left Rear Door Tweeter BK Left Rear Door (REAR DOOR CONNECTORS)
Left Rear Door Woofer BK Left Rear Door (REAR DOOR CONNECTORS)
Left Remote Radio Switch Steering Column N/S
Left Speed Control Switch WT Steering Column N/S
Left Tail Lamp Assembly BK At Lamp N/S
Left Visor/Vanity Lamp At Left Visor (OVERHEAD CONNECTORS)
License Lamp At Lamp N/S
Liftgate Ajar Switch At Liftgate (LIFTGATE CONNECTORS)
Liftgate Cylinder Lock Switch NAT At Liftgate (LIFTGATE CONNECTORS)
Liftgate Lamp BK At Liftgate (LIFTGATE CONNECTORS)
Liftgate Power Lock Motor At Liftgate (LIFTGATE CONNECTORS)
Line Pressure Sensor Right Side of Transmission (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (EXCEPT CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7 (4X4) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (EXCEPT CALIFORNIA))
Low Note Horn BK At Horn (RIGHT FRONT ENGINE COMPARTMENT)
Manifold Absolute Pressure Sensor BK On Throttle Body (ENGINE LEFT SIDE 5.9L), (ENGINE CONNECTORS FRONT 4.7L)
Mode Door Actuator Right Center of Instrument Panel N/S
Multi-Function Switch GY At Steering Column (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (MULTI-FUNCTION SWITCH CONNECTORS)
Output Speed Sensor BK Under Transmission, Left Side of Transmission (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X2)), (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (EXCEPT CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (EXCEPT CALIFORNIA))
Overdrive Switch NAT At Steering Column (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (MULTI-FUNCTION SWITCH CONNECTORS)
Overhead Console Headliner (OVERHEAD CONNECTORS)
Oxygen Sensor 1/1 Upstream BK At Oxygen Sensor (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X2)), (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (EXCEPT CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (EXCEPT CALIFORNIA))
Oxygen Sensor 1/2 Downstream BK At Oxygen Sensor (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X2)), (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (EXCEPT CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (EXCEPT CALIFORNIA))
Oxygen Sensor 2/1 Upstream BK At Oxygen Sensor (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X2)), (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7 (4X4) (CALIFORNIA))
Oxygen Sensor 2/2 Downstream BK At Oxygen Sensor (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X2)), (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7 (4X4) (CALIFORNIA))
Park Brake Switch Left Side of Instrument Panel (BODY WIRING)
Passenger Airbag YL Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Passenger Blend Door Actuator Right Center of Instrument Panel N/S
Passenger Lock Cylinder Switch LTGY Passenger Door N/S
Passenger Door Power Lock Motor/Ajar Switch BK Passenger Door N/S
Passenger Door Power Lock Switch NAT Passenger Door N/S
Passenger Door Power Window Motor BK Passenger Door N/S
Passenger Door Power Window Switch BL Passenger Door N/S
Passenger Heated Seat Under Passenger Seat (BODY WIRING)
Passenger Heated Seat Switch BL Under Passenger Seat N/S
Passenger Power Lumbar Motor Under Passenger Seat N/S
Passenger Power Mirror Passenger Door N/S
Passenger Power Seat Motors Under Passenger Seat N/S
Passenger Power Seat Switch Under Passenger Seat N/S
Passenger Seatbelt Tensioner Pillar Between Passenger Doors (BODY WIRING)
Power Outlet BK Upper Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Power Steering Pressure Switch BK Near Power Steering Pump (ENGINE LEFT SIDE 4.7L)
Powertrain Control Module-C1 BK At Powertrain Control Module (RIGHT REAR ENGINE COMPARTMENT)
Powertrain Control Module-C2 WT At Powertrain Control Module (RIGHT REAR ENGINE COMPARTMENT)
Powertrain Control Module-C3 GY At Powertrain Control Module (RIGHT FRONT ENGINE COMPARTMENT), (RIGHT REAR ENGINE COMPARTMENT)
Radiator Fan Motor BK Below Radiator (RIGHT FRONT ENGINE COMPARTMENT)
Radio-C1 GY Upper Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
Radio-C2 BK Upper Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
Radio-C3 NAT Upper Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
Radio Case Ground Upper Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
Rear A/C Heater Control Between B-Pillars in Headliner (OVERHEAD CONNECTORS)
Rear Blend Door Actuator Between B-Pillars in Headliner N/S
Rear Blower Motor Right Side of Rear Cargo Area N/S
Rear Blower Motor Resistor Right Side of Rear Cargo Area N/S
Rear Dome Lamp BK At Lamp in Headliner (OVERHEAD CONNECTORS)
Rear Heater Coolant Pump Right Fender Side Shield N/S
Rear Mode Door Actuator At Right Rear Mode Door N/S
Rear Power Outlet BK At Outlet (REAR BODY WIRING)
Rear Washer Pump Motor BK At Washer Fluid Reservoir (RIGHT FRONT ENGINE COMPARTMENT)
Rear Wheel Speed Sensor BK At Rear Axle (TRAILER TOW CONNECTOR)
Rear Window Defogger BK In Liftgate (LIFTGATE CONNECTORS)
Rear Wiper Motor In Liftgate (LIFTGATE CONNECTORS)
Recirculation Door Actuator Right Center of Instrument Panel N/S
Right Fog Lamp WT At Lamp (RIGHT FRONT ENGINE COMPARTMENT)
Right Front Door Tweeter NAT Right Door N/S
Right Front Door Woofer Right Door N/S
Right Front Park/Turn Signal Lamp No.1 BK At Lamp (RIGHT FENDER AREA)
Right Front Park/Turn Signal Lamp No.2 BK At Lamp (RIGHT FENDER AREA)
Right Front Side Marker Lamp At Lamp (RIGHT FENDER AREA)
Right Front Wheel Speed Sensor LTGY Right Fender Side Shield (RIGHT FRONT ENGINE COMPARTMENT)
Right Headlamp BL At Lamp (RIGHT FENDER AREA)
Right Rear Door Power Lock Motor/Ajar Switch BK Right Rear Door N/S
Right Rear Power Window Motor BK Right Rear Door N/S
Right Rear Power Window Switch BL Right Rear Door N/S
Right Rear Door Tweeter BK Right Rear Door N/S
Right Rear Door Woofer BK Right Rear Door N/S
Right Remote Radio Switch Steering Column N/S
Right Speed Control Switch WT Steering Column N/S
Right Tail Lamp Assembly BK At Lamp (TAIL LAMP AREA)
Right Visor/Vanity Lamp At Visor (OVERHEAD CONNECTORS)
Seatbelt Switch NAT Near Left Rear Speaker, at Seatbelt Switch (BODY WIRING)
Sentry Key Immobilizer Module BK On Steering Column (LEFT SIDE INSTRUMENT PANEL CONNECTORS), (MULTI-FUNCTION SWITCH CONNECTORS)
Shift Bezel Lamp Lower Center of Instrument Panel (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS), (INSTRUMENT PANEL CONNECTORS)
Speed Control Servo BK Right Fender Side Shield (RIGHT FRONT ENGINE COMPARTMENT)
Throttle Position Sensor (5.9L) GY On Throttle Body (ENGINE LEFT SIDE 5.9L)
Throttle Position Sensor (4.7L) GY On Throttle Body (ENGINE LEFT SIDE 4.7L)
Trailer Tow BK Rear of Frame (TRAILER TOW CONNECTOR)
Transfer Case Control Module-C1 Right Side of Steering Column (INSTRUMENT PANEL CONNECTORS)
Transfer Case Control Module-C2 Right Side of Steering Column (INSTRUMENT PANEL CONNECTORS)
Transfer Case Control Module-C3 Right Side of Steering Column (INSTRUMENT PANEL CONNECTORS)
Transfer Case Mode Sensor BK Side of Transmission (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (CALIFORNIA))
Transfer Case Selector Switch BK Center of Instrument Panel at Switch (RIGHT SIDE/CENTER INSTRUMENT PANEL CONNECTORS)
Transfer Case Shift Motor BK Side of Transmission (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (CALIFORNIA))
Transmission Control Module BK Right Front of Engine Compartment N/S
Transmission Range Sensor BK On Transmission (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X2)), (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4))
Transmission Solenoid Assembly BK Left Side of Transmission (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X2)), (AUTOMATIC TRANSMISSION CONNECTORS 5.9L (4X4))
Transmission Solenoid/TRS Assembly BK Left Side of Transmission (AUTOMATIC TRANSMISSION 4.7L (4X2) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X2) (EXCEPT CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (CALIFORNIA)), (AUTOMATIC TRANSMISSION 4.7L (4X4) (EXCEPT CALIFORNIA))
Washer Fluid Level Switch GY At Washer Fluid Reservoir (RIGHT FRONT ENGINE COMPARTMENT)
Old 11-12-2011, 08:47 AM
WyzGuy's Avatar
WyzGuy
WyzGuy is offline
Answer: To the right of the accelerator pedal on the side of the trans tunnel. Need to pull the carpet down to see it.
Quick Reply: Ground G207 location?
