Body Control Module
Old 11-05-2011, 07:37 AM
rainbo's Avatar
rainbo
rainbo is offline
Default Body Control Module
1997 Ram B2500 van, 318 engine. Where is the BCM located? Best to by a new one and have the dealer reprogram it or are the companies where you send your old one to be redone better? Company or brand recommendation?
Old 11-06-2011, 01:07 AM
stev's Avatar
stev
stev is offline
Are you talking the BCM or the PCM ????
The BCM controls the dash gauges primarily, the power door locks and the airbag system. Actually everything that is not engine related. The PCM is the entire vehicle engine computer. Usually, if the dash gauges go out, the van can still run and drive. But, you have no idea what's going on otherwise.
Usually the Chrysler p/n for our vans for the BCM is a TRW 68HC11K4 or 68HC11KA4. The BCM is used by OBD-II feedback. Not sure what the extra "A" difference is with the p/n's. I thought that the BCM was offered in 1998 to 2003. Yours being a 1997 is odd having the older dash design that has no digital feedback and not OBD-II ready.
Old 11-06-2011, 07:51 AM
rainbo's Avatar
rainbo
rainbo is offline
Default Location
So where are both located? All interior lights went out, the radio stopped working, and the check engine light came on but they say there is no power to the scan connection. Help!
Old 11-06-2011, 10:32 AM
stev's Avatar
stev
stev is offline
The PCM is under the tinny hood, right in the middle at the top. Look for a casted aluminum box thing with three wire bundles going to it.
As for the BCM, it was mentioned that its' part of the instrument cluster or that it is located under the drivers' seat. I've only known one other person that posted in a Dodge Ram Van forum about this problem but never got word back of the BCMs actual location.
And FYI, the Ram Truck BCM is not the exact same as the Ram Van. They are similar though.
Old 11-08-2011, 09:13 PM
Rusty93RamVan's Avatar
Rusty93RamVan
Rusty93RamVan is offline
BCM for a 97 should be under the Driver's seat.
Old 11-08-2011, 11:24 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Mobile Auto Repair is offline
97 van does not have a BCM. 98-03 have them and some of them are built into the PCM according to another member on this forum.
For the 94-97's
PCM under the hood on the firewall
ACM (Airbag Control Modul) under the drivers seat
RWAL under the glove box insert
Check the fuses under the hood in the PDC (Power Distribution Center) on top/beside the radiator. I believe you will find a blow maxi fuse in there.
Old 11-09-2011, 08:25 PM
Rusty93RamVan
What was that crap under the seat of my 97 then? Airbag control?
Old 11-10-2011, 07:16 AM
Mobile Auto Repair
The Airbag Control Module, for the airbag in the steering wheel.
Quick Reply: Body Control Module
