It's actually fixed (governor pressure sensor/solenoid)
Old 10-26-2011, 09:47 PM
2000DakotaQuad's Avatar
2000DakotaQuad
2000DakotaQuad is offline
Red face It's actually fixed (governor pressure sensor/solenoid)
So for the second time in 4 days I took off the trans pan and replaced the governor pressure sensor and solenoid. The first time I used parts from a junk yard off a 2000 Ram with the same model tranny. And what do you know those were bad too....my luck. This time I bought new parts off transmissionpartsusa, literally 50-75% less then what my local dodge dealer was charging, and what do you know. I backed it up to the road put it in drive and just touched the gas and up comes the front end and we have lift off. I got my power back, I got first gear back, and it freaking works. Thanks Master Tech for the help
If you are thinking of doing your own its very easy. From first bolt off to last one on it took me 1 1/2 hours. 90% of that time is draining fluid
Old 10-26-2011, 11:34 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Great job! Thats why I am here.
Old 10-26-2011, 11:47 PM
jondakotaguy's Avatar
jondakotaguy
jondakotaguy is offline
Sorry; dont think i seen the orginal thread; what was the original symptoms?
Old 10-27-2011, 07:08 AM
2000DakotaQuad
code 1762 and 1756
Old 11-17-2011, 12:24 PM
crashgordan's Avatar
crashgordan
crashgordan is offline
were the parts you bought OEM or aftermarket?? and i'm curious of aftermarket is OK or stay away from them...
Quick Reply: It's actually fixed (governor pressure sensor/solenoid)
