Vacuum to axle shift motor
Old 10-25-2011, 08:30 PM
iacordero's Avatar
iacordero
iacordero is offline
Default Vacuum to axle shift motor
Alright, so I've searched up and down for a vacuum line diagram for a 5.9L V8 RAM 1500 4x4, and have come up empty-handed. Here's the deal: I was looking into the engine bay, and saw that there is a hose coming from the axle shift motor, but it isn't connected to anything; it just has a coupler at the end of it where it's attached to the frame of the truck. I can only assume it's a vacuum line because it's not leaking any fluid. However, I can't find where that line should be drawing vacuum from, which means that I have a vacuum leak somewhere. I looked all over the place for the other half of that line and can't find anything. Here are a couple of pictures to hopefully illustrate, and yes, I am aware that my axle is leaking.
Old 10-25-2011, 08:53 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
its just the axle breather tube. has nothing to do with vacuum.
Old 10-25-2011, 08:56 PM
iacordero's Avatar
iacordero
so, it's supposed to be open-ended like that?
Old 10-25-2011, 08:58 PM
Terribly's Avatar
Terribly
Terribly is offline
I cant really tell by the pictures, but is the line on top? And is it not the breather vent tube?
Old 10-25-2011, 09:05 PM
97black_ram's Avatar
97black_ram
97black_ram is offline
That's the breather hose. The two smaller lines below it are for the vacuum and they go up to the pass. side frame and goes back to a plug on top the transfer case.
Old 10-25-2011, 09:47 PM
iacordero's Avatar
iacordero
Should that breather tube be facing downward to keep water from getting in the axle tube, then?
Old 10-25-2011, 09:53 PM
chadhager03's Avatar
chadhager03
chadhager03 is offline
It has (or should) have a little plastic cap on top to prevent water from going in there.
Old 11-01-2011, 06:45 PM
iacordero's Avatar
iacordero
On a related note - as you saw from the pictures I posted, my front axle leaks at the shift motor, and recently (as of about two weeks ago) ive been hearing a pretty noticeable humming sound coming from somewhere around the front axle. I'm running 315/75r16 kumhos and they're about ready to be retired, so I'm having trouble identifying whether the humming is coming from the tires or the differential. I guess the question is: even if the diff is low on fluid, would it hum if the front gears aren't engaged? I don't want the thing to lock up on me going down the road, and I haven't been able to find the time to fix that leak. Any input would be greatly appreciated.
Old 11-01-2011, 07:00 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
How about just checking the fluid level and adding once a week? Until you can get to fixing the leak. Or are you just going to let it run dry and wonder where the humming is coming from?
Old 11-01-2011, 07:57 PM
Terribly's Avatar
Terribly
Terribly is offline
To replace that shift cover gasket only takes about twice as long as it does to top off the fluid
Quick Reply: Vacuum to axle shift motor
