2002 stratus r/t coupe 3.0 heater problems.
Old 10-23-2011, 10:23 PM
stratusr/t02's Avatar
stratusr/t02
stratusr/t02 is offline
Exclamation 2002 stratus r/t coupe 3.0 heater problems.
Have an 02 stratus r/t 3.0 replaced water pump,rad,rad cap,t-stat and flushed the system and eveything is fine nothing is clogged up.The problem is there is heat on the passenger side and the driver side is blowing cold air.Checked the cables to the box and can hear the doors moving,is there something that I am over looking.It started this before I changed the water pump this is why I replaced it thinking this was the problem.I hate to have to take the dash out to find the problem.Any help would be great thanks.
Old 01-04-2012, 06:22 AM
demdog's Avatar
demdog
demdog is offline
flush heater core the opposite direction of flow, worked for me
Old 11-10-2013, 05:36 PM
Capone0716's Avatar
Capone0716
Capone0716 is offline
hey man what did you do to fix this. I am having the same issue you were. There's heat coming out the passenger side vents but cold air coming out the drivers side
Old 11-10-2013, 05:57 PM
NH R/T's Avatar
NH R/T
NH R/T is offline
same here someone PLEASE HELP
Old 11-28-2013, 11:54 AM
rwhalen501's Avatar
rwhalen501
rwhalen501 is offline
I have the same issue tried to reset the system twice removing the fuse and the battery cable for a time it didnt work the instruction I read on otherposts says tem minutes.
Does the length of time matter is this a time sensitive thing?
Quick Reply: 2002 stratus r/t coupe 3.0 heater problems.
