Need Torque Specs for 1998 318
Old 10-23-2011, 09:40 PM
druiddevil's Avatar
druiddevil
druiddevil is offline
Default Need Torque Specs for 1998 318
I am in the process of rebuild my 1998 318 engine (from a carry-over of I cannot drive me dodge Dakota sport 35 thread). I am very close to being finished, but I just realized I have no idea of the torque specs for the engine. Can someone please tell me or point me towards the direction to find the specs for torquing the: headers, heads, manifold intake, rocker arms, lifter, heck the whole engine!
This community has been a great help for me while I have been doing this build. I have had three dodge trucks, but this is the first I have actually built almost from scratch. I just wish to thank all those that have given me advice and for being a pretty decent forum of which I am proud to be a member.
Old 10-23-2011, 09:43 PM
thunder98110's Avatar
thunder98110
thunder98110 is offline
get a haynes manual, problem solved.
Old 10-23-2011, 11:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
The service manual is downloadable from the stickies and the FAQ above this post. It will have all the torque specs and bolt patterns ect.
Old 10-24-2011, 01:19 AM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
Crazy4x4 is right but thunder's idea is even better saves running in the house when you are not sure of something. They are great to have around and even carry in your truck. Plus the cost is very low like 15.00 or 20.00. If im bored and have to kill some time ill pick mine up and read a chapter or 2. Comes in very handy lol
Old 10-24-2011, 11:27 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Free is better then paying for an incomplete manual, Chiltons and Haynes suck. The service manual that we got is made by Dodge and is 100% complete.
But you did bring up a good point, it is nice to have something at the truck side when you need to refer back to it. For me I have a laptop so having it outside is no problem and it is searchable, type in a work and it will search for those times you can't find what you need. I keep it on the drivers seat where it wont fall or get dirt ect.
But having a paper book is nice where it doesn't care about getting dropped or dirty. The best option would be the paper Factory service manual which unfortunately is $90 or so. But we got that to download free in PDF format.
Old 10-24-2011, 08:30 PM
moe7404's Avatar
moe7404
moe7404 is offline
i bet you didnt know that a 318 has a higher head bolt torque than a 440. why? cause the 318 has larger, and fewer, head bolts than a 440. a 318 has 4 bolts around a cylinder, a 440 has 5 bolts around each cylinder. that's free.
Old 10-25-2011, 12:14 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
This is also free.
TORQUE SPECIFICATIONS
DESCRIPTION TORQUE
Camshaft
Bolt 68 N·m (50 ft. lbs.)
Camshaft Thrust Plate
Bolts 24 N·m (210 in. lbs.)
Chain Case Cover
Bolts 41 N·m (30 ft. lbs.)
Connecting Rod Cap
Bolts 61 N·m (45 ft. lbs.)
Crankshaft Main Bearing Cap
Bolts 115 N·m (85 ft. lbs.)
Crankshaft Pulley
Cylinder Head
Bolts (1st Step) 68 N·m (50 ft. lbs.)
Bolts (2nd Step) 143 N·m (105 ft. lbs.)
Cylinder Head Cover
Bolts 11 N·m (95 in. lbs.)
Engine Support Bracket to Block (4wd)
Exhaust Manifold-to-Cylinder Head
Bolts/Nuts 34 N·m (25 ft. lbs.)
Flywheel
Bolts 75 N·m (55 ft. lbs.)
Front Insulator (All)
Through bolt/nut 95 N·m (70 ft. lbs.)
Front Insulator to Support Bracket (4wd)
Stud nut 41 N·m (30 ft. lbs.)
Through bolt/nut 102 N·m (75 ft. lbs.)
Front Insulator to Block (2wd)
Bolts 95 N·m (70 ft. lbs.)
Generator
Mounting Bolt 41 N·m (30 ft. lbs.)
Intake Manifold
Bolts Refer to R &I Procedure
Oil Pan
Bolts 24 N·m (215 in. lbs.)
Oil Pan
Drain Plug 34 N·m (25 ft. lbs.)
Oil Pump
Attaching Bolts 41 N·m (30 ft. lbs.)
Oil Pump Cover
Rear Insulator-to-Bracket (2WD)
Through-Bolt 68 N·m (50 ft. lbs.)
Rear Insulator-to-Crossmember Support Bracket (2WD)
Nut 41 N·m (30 ft. lbs.)
Rear Insulator-to-Crossmember (4WD)
Nuts 68 N·m (50 ft. lbs.)
Rear Ins
Old 10-25-2011, 06:28 PM
moe7404's Avatar
moe7404
moe7404 is offline
great info master tech . my books are much older, so i thought my info might be to far off.
Old 10-25-2011, 09:53 PM
chris1996's Avatar
chris1996
chris1996 is offline
just print it and have the free one with only the cost of print
Quick Reply: Need Torque Specs for 1998 318
