Serpentine belt, belt tensioner pulley, idler pulley
Old 10-22-2011, 12:31 AM
Aerogauge's Avatar
Aerogauge
Aerogauge is offline
Default Serpentine belt, belt tensioner pulley, idler pulley
I want to replace my serpentine belt, tensioner pulley, idler pulley. My truck makes an annoying squeeking sounds whenever its wet outside and I believe its the pully's and belt. Wouldnt this be straightforward? Remove belt, unbolt the 1 bolt from the pully and replace then put on the new belt?
Old 10-22-2011, 01:12 AM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
Yup.
-Tighten the tensioner pulley bolt to loosen the belt.
-Loosen the bolt to remove pulley--then install new tensioner pulley.
-Loosen idler pulley bolt--install new one.
-clean all the pulleys w/ wire brush or scotch brite pad.
I just did this today--didn't help the squeaking at all.
Make sure you check all your pulleys for dirty/squeaking bearings; water pump, a/c, tensioner, idler, power steering, alternator. check for any play in the pulleys.
When the engines running look at all the pulleys for excessive wobble. crankshaft should wobble a little. Check you power steering fluid, I heard if it's low the belt (or maybe the pump) will squeak.
If all else fails and it's still squeaking, get a new tensioner--RockAuto has 'em for $40 + shipping.
Old 10-22-2011, 01:18 AM
Aerogauge's Avatar
Aerogauge
Thanks, I will be a bit pissed if I change them and it still squeeks
Old 10-22-2011, 07:12 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Get Dayco brand if you can. And make sure everything has the same amount of ribs.
Quick Reply: Serpentine belt, belt tensioner pulley, idler pulley
