Replacing rear brake lines on a 98 FWD Caravan, have some questions
Old 10-07-2011, 08:30 PM
cabech984's Avatar
cabech984
cabech984 is offline
Default Replacing rear brake lines on a 98 FWD Caravan, have some questions
I'm replacing the rear brake lines on a family member's 1998 Grand Caravan FWD(3.0 V6). I have the fuel tank down and the old lines removed in between the proportioning valve and the hydraulic rubber lines. I was curious what size the fittings on both ends were as well as what size of line to use. I bought some 3/16" line and was unable to find new fittings for both sides of the lines that would fit, which got me wondering if the line was possibly the wrong size. Oh yeah, I may be incorrect but I believe this van doesn't have rear ABS. It has the height sensing actuator attached to the leaf spring.
I would greatly appreciate any help!
Old 10-07-2011, 10:22 PM
cabech984's Avatar
cabech984
I found that I am correct with the brake line(3/16) and a regular 3/16" fitting(with a double inverted flare) fits in one side of the proportioning valve, but it won't fit the other side. I haven't checked the hydraulic rubber line side since I won't have them until tomorrow morning. Any help would be great so I don't buy the wrong fittings! Thanks!
Old 10-08-2011, 12:35 PM
cabech984's Avatar
cabech984
Nevermind, I found the correct size brake line fittings for the rear components. Hope these help someone else someday!
3/16" brake line
3/8 x 24 (3/16" line) inverted flare fittings
7/16 x 24 (3/16" line) inverted flare fittings
Old 03-20-2013, 10:19 PM
rdbarta's Avatar
rdbarta
rdbarta is offline
it did help. Thanks for the info, was looking for the same info for the same reasons..
Old 05-03-2013, 05:47 PM
carlmn's Avatar
carlmn
carlmn is offline
Thanks for the fitting and line size info, cabech984. I'm about to drop the tank on my 96 Caravan to replace the two lines running above it - one of which is leaking and the other of which looks like it could go any moment.
Old 04-01-2018, 09:16 AM
BigRed92's Avatar
BigRed92
BigRed92 is offline
Thx for the info, I am about to replace a section of my rear brake lines on my 99 GC 3.3l.
Quick Reply: Replacing rear brake lines on a 98 FWD Caravan, have some questions
