1995 Dodge Ram 1500 SLT Magnum V8
Old 10-04-2011, 03:41 AM
vern2459's Avatar
vern2459
vern2459 is offline
Default 1995 Dodge Ram 1500 SLT Magnum V8
I have a 1995 Dodge Ram 1500 SLT Magnum V8. Iam not sure what too call it,but when i go too shift gears from parked too Drive,Reverse or any other gear,the shifting marker does not matchup with the gear letter indicator.... You have too go passed drive too 1st then back up too find the DRIVE gear,,,, because on the way down you can shift it into DRIVE but on the gear indicator panel it isnt aligned with the letter D and so on for the other gears..... it runs well...but the alignment for the desired gears are not exactly in line or centered on the letter of gear your in....
When your in DRIVE your indicator ls in between Neutral and Drive.... and so forth
1.My question is can this be adjusted or what exactly causes this too happen?
2.And what is the name of the gear shifting display panel on the steering column?
3. What exactly do you have too adjust to fix this problem?
Vern2459
Old 10-04-2011, 07:48 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Welcome to DF.
First, before anything else, please read this:
https://dodgeforum.com/forum/dodge-ra...s-section.html
I will move this to the 2nd gen section for ya. This will probably help you out.
Old 10-04-2011, 07:52 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Vern2459
Adjust the white plastic screw.
Old 10-04-2011, 07:57 PM
TheMikeEustis's Avatar
TheMikeEustis
TheMikeEustis is offline
mine is similar but not exact. If I go from park straight to drive, it acts a neutral. However, if I go from Park, drag it down to "1" (still not moving) and then bring back up to Drive, it goes into drive, no problem. Can this be fixed by playing with that screw in the picture, and where exactly is that?
Old 10-04-2011, 08:01 PM
zman17's Avatar
zman17
zman17 is offline
It's behind the knee panel on the the steering column. Doesn't sound like that's your problem anyway. In your case, I'd check the linkage.
Old 10-04-2011, 08:11 PM
TheMikeEustis
where would I check the linkage? like on the lever or the transmission or where? I never fooled around too much down there so I don't want to mess with the wrong thing, plus I'm Polish
Old 10-04-2011, 08:23 PM
zman17's Avatar
zman17
zman17 is offline
LMAO, so am I, and that's no excuse. Check it all, from steering column by brake booster, all the way down to the tranny.
Old 10-04-2011, 08:33 PM
TheMikeEustis
psh, I use that as my excuse for just about everything lol and what would I be checking for? Loose connections, fray, anything that doesn't look healthy?
Old 10-04-2011, 08:34 PM
Sloppy bushings, bent parts, things of that nature. (some of the parts are SUPPOSED to be bent though...... )
Old 10-04-2011, 08:38 PM
zman17's Avatar
zman17
zman17 is offline
LOL, only the polish parts. hahahaha
Quick Reply: 1995 Dodge Ram 1500 SLT Magnum V8
