2004 Dodge Ram Transmission Problem
Old 09-30-2011, 11:40 PM
sbachart's Avatar
sbachart
sbachart is offline
Default 2004 Dodge Ram Transmission Problem
HELP!
My transmission went out and got stuck in 3rd gear about 60 miles from my house. I recently had the transmission rebuilt with a master rebuild kit, and had to replace the valve body due to physical damage caused by a piece of metal from inside the transmission. My truck will now shift from 1st to 2nd to 3rd, but will not shift into overdrive. I've been reading a lot about the TCM quick learm procedure. Can my truck be reading the old value from when I was stuck in 3rd gear? Would this quick learn fix the problem?
Please Help, I have a 17 year old dying to drive this truck.
Thank You
Old 10-01-2011, 12:56 AM
vpnavy's Avatar
vpnavy
vpnavy is offline
Welcome Aboard sbachart! Stay tuned - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Ram for stuff related to your ride.
Old 10-01-2011, 07:37 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Quick Reply: 2004 Dodge Ram Transmission Problem
