Standardized Towing is coming; is it good or bad?
Old 09-29-2011, 08:52 PM
DodgeForum Editor's Avatar
DodgeForum Editor
DodgeForum Editor is offline
DF Editor
Default Standardized Towing is coming; is it good or bad?
Check out BadStratRT's homepage article about Standardized tow rating testing. Is this good or bad?
Old 09-30-2011, 08:18 AM
rodslinger's Avatar
rodslinger
rodslinger is offline
Default Good...
It would be nice to have clear and objective data to compare. Nothing worse than bringing home that fancy new widget with claimed specifications only to be routinely disappointed since your real world operating conditions can't match the lab scenario your widget was tested in....
Old 09-30-2011, 12:15 PM
JETwagen's Avatar
JETwagen
JETwagen is offline
I am surprised this hasn't been done sooner. I ask why can't ALL vehicles that claim towing capacity have standardized testing if they aren't already (i.e. vans, wagons, etc.)
Old 10-01-2011, 09:33 AM
neoncrazy101's Avatar
neoncrazy101
neoncrazy101 is offline
I think its good and just like JET I'm surprised it hasn't been standardized sooner. I'm curious as to how much it will affect the Big 3, especially in the 1-ton category.
Will this also have to be standard on like SUV's and such or just trucks?
Old 10-03-2011, 09:09 AM
shieldsdb's Avatar
shieldsdb
shieldsdb is offline
Motor Trend did something like that back in 08 or 09. It just wasn't for max weight. They tested each of the 1/4 ton trucks available. I think they pulled 3500 lbs each. Tested: 0-60 time, 35-70 time, 70-0 time with notes on stability while doing it. I think they also tested stability at highway speed over different road types. They tested everything on flat roads and inclines, plus measured trans temp, break wear and mpg over the whole test.
Old 10-03-2011, 09:28 AM
shieldsdb's Avatar
shieldsdb
Damn, I didn't even answer the question. It's a good idea. Worst case, you buy a truck with a crappy tow rating, but you already know that it has it! It would save you a lot of money on repairs. Manufacture says 9K lbs, you try 8k, only to find it will only handle 6k. There goes the transmission!!! (among other things)
Old 10-04-2011, 08:54 PM
Trevor10's Avatar
Trevor10
Trevor10 is offline
Default Great Idea
This is the best idea for comparing trucks because lets face it FORD blows but they say they tow as much as they do.
HA well thats my opinion anyways. lol
Old 10-08-2011, 07:39 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
I think it is a good thing because most are probably lying. Just because an engine makes the power to pull something, it also has to be a stable platform and have more than enough braking. All of this in long distances and in all conditions.
Remember the old Tundra ads that showed them towing over 11K lbs?
Now their highest rated tow rating is 10K.
There needs to be a set standard and maybe even a 3rd party involved in the rating.
Quick Reply: Standardized Towing is coming; is it good or bad?
