Main cap torque specs and sequence
Old 09-28-2011, 06:06 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
Default Main cap torque specs and sequence
Can anybody tell me the torque specs for the Main caps and the sequence to tighten them in? I can't find my book and need to know in the next couple of hours.
Old 09-28-2011, 07:32 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
main caps - step 1 - 20 ft lb. step 2 - 85.
rod caps - 45
torque seq - from center outwards.
from haynes -
tighten all except thrust caps to 20. tighten thrust to 10.
tap ends of crank back and forth to lineup the thrust bearing and crank.
torque to 85 from center out.
rotate and inspect.
check crankshaft endplay.
Old 09-28-2011, 08:34 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
Thank you very much
Old 09-28-2011, 01:10 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Next time your in a pinch like that, and it's early and or no one here. Don't forget the service manuals in the FAQ section.
Old 09-28-2011, 01:27 PM
matty675's Avatar
matty675
matty675 is offline
assuming you're using bolts...
Old 09-28-2011, 02:58 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
My iPhone doesn't like it very much lol
Quick Reply: Main cap torque specs and sequence
