1998 Intrepid Wheel Hub Nut Size
Old 09-25-2011, 11:06 AM
MDThomas26's Avatar
MDThomas26
MDThomas26 is offline
Default 1998 Intrepid Wheel Hub Nut Size
Does anyone know what size the nut on that holds the wheel hub on the drive axel is?
Using my micrometer I estimate it to be about a 1 1/4 maybe 1 3/16.
I assumed this was not a standard nut since nothing else appears to be on the car (and I have gone deep into this car) so I did the conversion and estimated between 32 and 33mm 32 is to small. The strange part is, every place I go for a socket will go from 32mm straight to 36mm.
Anyway, if anyone knows exactly what it is I'd love to be enlightened. As a last resort I am going to call the local Dodge dealer.
Thanks as always for all the great help on this forum!!
Old 09-25-2011, 08:21 PM
22mopar22's Avatar
22mopar22
22mopar22 is offline
On my car it's 1 5/16 or like 34mm. Every autoparts store I deal with has this size, so does harbor freight, Sears, and probably your local home improvement store.
Old 02-29-2012, 12:31 AM
ponchaz's Avatar
ponchaz
ponchaz is offline
on my 98 its a 34mm. I just replaced my front wheel bearing hubs and that was the size needed to remove the axle nut.
Quick Reply: 1998 Intrepid Wheel Hub Nut Size
