Radiator question.
Old 09-22-2011, 10:07 PM
j_son600's Avatar
j_son600
j_son600 is offline
Default Radiator question.
Anyone know if there's any difference between the 00-04 radiator's and an 05's? Sorry for the stupid question, just been a long week and every radiator I find says 00-04 Thanks..
Old 09-22-2011, 10:19 PM
steak59's Avatar
steak59
steak59 is offline
I believe the trans cooler line fitting is different.
Old 09-26-2011, 10:00 PM
j_son600's Avatar
j_son600
j_son600 is offline
Another quick question, what is needed to remove the trans cooler lines?
Old 09-27-2011, 02:41 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
My transmission had been removed before, so mine were just fluid lines on barbed fittings. Looked like they were cut? Probably from the factory connectors?
Old 10-02-2011, 08:56 AM
vicsponjr's Avatar
vicsponjr
vicsponjr is offline
If your trans lines are the screw in type like my 2005 SXT, the nut size was 18mm, open wrench.
The new radiator I ordered has the hose type fittings. The fittings look like they scew in. I haven't had time yet but I want to see if they do unscrew so I can screw in the transmission lines. If not I guess I either have to send it back or cut off the screw in fittings and use a patch hose (not what I want to do)
Old 10-06-2011, 06:29 AM
vicsponjr's Avatar
vicsponjr
In case anyone else comes accross this...
The radiator I ordered was csf3180 for my 2005 Neon SXT. It had two male hose end fittings for the transmission cooler. The male fittings DO NOT unscrew from the trans cooler. The nuts on them only hold the cooler in place.
My old radiator had screw in trans lins. The screw in fittings are help on with snap rings. Once I removed the snap rings the screw in fittings came off to reveal male hose type fittings. I connected the two male fittings with 3/8 transmission hose and hose clamps.
Old 10-10-2011, 01:28 AM
j_son600's Avatar
j_son600
j_son600 is offline
My new radiator was the same, 2 pieces of 6" 3/8's trans cooler line and 4 clamps later I'm back good as new.
Quick Reply: Radiator question.
