Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
How to change/replace water pump in 2007 Dodge Nitro?
Old 09-22-2011, 11:29 AM
chastarenee's Avatar
chastarenee
chastarenee is offline
Default How to change/replace water pump in 2007 Dodge Nitro?
I was able to get the water pump off, but now i am having trouble putting it back on. Any tips?
Old 09-24-2011, 11:17 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
Here is some information. I also do have pictures if you need them too. Just let me know.
The water pump (1) on 3.7L engines is bolted directly to the engine timing chain case cover (2).
1. Clean gasket mating surfaces.
2. Using a new gasket, position water pump and install mounting bolts as shown. Tighten water pump mounting bolts to 54 N·m (40 ft. lbs.) torque.
3. Spin water pump to be sure that pump impeller does not rub against timing chain case/cover.
4. Connect radiator lower hose to water pump.
5. Install accessory drive belt.
6. Position upper fan shroud and fan blade/viscous fan drive assembly.
7. Be sure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
8. Install two fan shroud-to-radiator screws.
9. Be sure of at least 25 mm (1.0 inches) between tips of fan blades and fan shroud.
10. Evacuate air and refill cooling system.
11. Connect negative battery cable.
12. Check cooling system for leaks.
Quick Reply: How to change/replace water pump in 2007 Dodge Nitro?
