Pulling Diagnostic Codes 2009 Dodge Caravan
Old 09-18-2011, 10:51 PM
treebean's Avatar
treebean
treebean is offline
Default Pulling Diagnostic Codes 2009 Dodge Caravan
I went to get the code and it gave me a _ _ _ _ _ _ _ _ then it flashed and read - Done -
But gave me no codes.. Can anyone help me out?
Thanks
Old 09-18-2011, 11:47 PM
gentz's Avatar
gentz
gentz is offline
why are you trying to pull codes? with what?
Old 09-19-2011, 12:32 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
+1. First of all you need a scanner the can read CAN and IHS Can bus system.
Old 09-19-2011, 01:12 PM
Marcus71's Avatar
Marcus71
Marcus71 is offline
Thanks
Sounds like your using the "key dance" by turning the key between "Off" and "On" position 3 times to pull codes. I believe your results means that there are no codes stored.
Quick Reply: Pulling Diagnostic Codes 2009 Dodge Caravan
