1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Transmission Shift Solenoid
Old 09-10-2011, 07:25 PM
2000DodgeAvenger's Avatar
2000DodgeAvenger
2000DodgeAvenger is offline
Question Transmission Shift Solenoid
I have 2000 Dodge Avenger that according to the CEL code its the transmission shift solenoid. How hard is this part to replace? Does anyone know what will progressively happen if this part is bad? Right now sometimes I have trouble with the car shifting sometimes I dont. It seems like when the car is not shifting it gets stuck in third but if i turn the car off and restart it, it will shift normally again. How long do I have before this part gives up all together and my transmission stops shifting?
Old 09-10-2011, 08:55 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
sounds more like the TCM
Old 09-10-2011, 10:04 PM
2000DodgeAvenger
isnt that the same thing? I searched for the transmission shift solenoid and thats what i found the transmission control module
Old 09-10-2011, 10:05 PM
2000DodgeAvenger
And if they are the same thing how hard is it to replace?
Old 09-11-2011, 09:16 AM
bad venge's Avatar
bad venge
Section Moderator
TCM = tranny control module = computer not the solenoid, the solenoid is switched by the computer by turning off the car I think its resetting the computer
Old 09-13-2011, 01:34 PM
2000DodgeAvenger
Question
Ok so if its the TCM would the CEL throw the code for the solenoid? Makes sence to be the TCM if after restarting it works, you would think if the solenoid needed replaced it would not shift all the time? Oh and today the CEL didnt come on when I started my car and stayed out the whole way to work?
Old 09-13-2011, 04:52 PM
bad venge's Avatar
bad venge
Section Moderator
The CEL says that it is not shifting it likely can't tell WHY meaning the solenoid isn't shifting but may or may not being told to
Old 10-20-2011, 06:54 PM
2000DodgeAvenger
Ok so we replaced the solenoid and the the TCM and it STILL does not shift!!! What else could be wrong???? PLEASE HELP!!!!!!
Old 10-20-2011, 08:29 PM
bad venge's Avatar
bad venge
Section Moderator
You need to have the tranny codes scanned /
Where did youget the TCM ? it might need reflashed/updated
Quick Reply: Transmission Shift Solenoid
