1995 Dodge Ram 1500 overdrive problems
Old 09-12-2011, 12:51 AM
marks18's Avatar
marks18
marks18 is offline
its a switch on the dash beside the switch for the foglights, but i will check into it probably take it apart and clean it up like the door lock and window switches
Old 09-12-2011, 09:57 AM
Button the the dash.
If you press the button, does the light come on??
Old 09-12-2011, 12:18 PM
marks18's Avatar
marks18
marks18 is offline
Yeah the light comes on and off. I'm also going to clean the throttle position sensor and the vehicle speed sensor and see if that corrects the problem. Other than that Idk what else it could be
Old 09-12-2011, 07:52 PM
marks18's Avatar
marks18
marks18 is offline
OK so I cleaned the tps and the vehicle speed sensor on the tranny and all connections and took apart the overdrive switch and cleaned the contacts and put it back together and still no overdrive?? Sorry for all the posting but I am just completely stumped
Old 09-12-2011, 08:34 PM
seabass202's Avatar
seabass202
seabass202 is offline
I had the same problem on my first transmission and did all the things that you have done to correct it with no success. last thing I did was purchase a transmission fluid pressure tester and learned from this forum and the FSM how to connect it to the test ports on the side of the transmission. turns out the overdrive circuit would not build sufficient pressure to operate the 800 pound overdrive spring. probably due to a leaking seal internally. replaced it with a rebuilt unit (transmission) and all good now. I believe mine failed due to the universal type crap fluid put in by one of those quick lane service joints.
Old 09-12-2011, 08:50 PM
marks18's Avatar
marks18
marks18 is offline
Ok thanks I will look into that, you got a completely rebuilt transmission or just the overdrive unit rebuilt and bolted back on?
Old 09-14-2011, 05:48 PM
seabass202's Avatar
seabass202
I got a rebuilt trans, but you could just rebuild the overdrive. I was looking at going that route till I found a deal on the whole trans. best deal I could find for the overdrive was actually on ebay.
Old 09-14-2011, 07:28 PM
Pacmanloads's Avatar
Pacmanloads
Pacmanloads is offline
My overdrive always worked , but when i wrecked my transmission when I took her swimming , the guy at the transmission shop told me the overdrive (planetary gears) were moments away from failure . I wish I would have taken some pictures , but i was still a little upset with all the money i was having to spend . Could be that the entire OD unit is just shot .
Old 09-14-2011, 09:46 PM
marks18's Avatar
marks18
marks18 is offline
Yeah I took it to a dodge transmission builder the other day and he said he doesnt think the solenoid is getting power?? Im dropping it off to him tomorrow morning and ill post my results, thanks for all the advice guys!!
Old 09-15-2011, 09:29 PM
marks18's Avatar
marks18
marks18 is offline
Ok here are the results!! The three wires to the solenoid are positive, ground for the torque converter lockup, and ground for the overdrive. There was a short between the pcm and the solenoid for both of the ground wires. Figured that out and got it re wired back up and now I have overdrive again but man that was a PITA
Quick Reply: 1995 Dodge Ram 1500 overdrive problems
