Oil pressure light flashes
Old 09-05-2011, 01:55 PM
calnhobes's Avatar
calnhobes
calnhobes is offline
Default Oil pressure light flashes
My oil pressure light flashes when I am stopped facing down hill. Any ideas? I have 2008 Dakota with 29K
Old 09-05-2011, 07:26 PM
marcsnyder05's Avatar
marcsnyder05
marcsnyder05 is offline
I would start with checking the oil. Do you have enough?
Old 09-05-2011, 09:08 PM
jkeaton is offline
Thanks....I was taking a drink of my beer when I read this....now my nose is burning.....lmao!
Old 09-05-2011, 09:27 PM
cheeseburger's Avatar
cheeseburger
cheeseburger is offline
CHECK YOUR OIL!!!! if in doubt add a little splash... but normally when that light is flashing... your in trouble...
Old 09-05-2011, 10:43 PM
thunder98110's Avatar
thunder98110
thunder98110 is offline
the light only comes on when its like less than 1Q i believe.
Old 09-06-2011, 02:47 PM
calnhobes's Avatar
calnhobes
Oil level is good. I have checked it several times, it doesn't flash all the time. If I put it in Park or N when I'm at a stop light it stops.
Old 09-06-2011, 03:11 PM
cheeseburger
Could be the sender
could be the sender.
Advanced auto parts oil pressure switch
If u read the reviews for this part someone talks about power steering fluid dripping onto it and shorting it out. its worth a look with a flashlight to see if its dry or covered in fluid. the switch (sensor) is by the oil filter btw.
Old 09-07-2011, 05:22 PM
calnhobes's Avatar
calnhobes
Thanks, hopefully that's all it is. The light never comes on while i'm driving nor does it fully light, just every now and then when I stop.
Old 09-12-2011, 01:58 PM
calnhobes's Avatar
calnhobes
Checked the oil pressure with a seperate pressure guage. It's putting out 10 and the standard it 7 psi I believe. What else could be causing the light to flash?
Quick Reply: Oil pressure light flashes
