Manual Transmission
Old 09-04-2011, 12:10 PM
4x4360's Avatar
4x4360
4x4360 is offline
Default Manual Transmission
Can I put a 5 speed transmission in my 99 4x4 Durango 5.9?
Thanks
Old 09-04-2011, 03:42 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
Durango doesn't have a 5 speed manual transmission in the USA. So if you wanted to replace the transmission you have now, You need to get a transmission from another model. Maybe a Ram or Dakota pickup. And may also need to replace the brake assy under the dash and wire harness and controller.
Old 09-04-2011, 05:22 PM
Freedog's Avatar
Freedog
Freedog is offline
Being that the Durango and Dakota are similar, I'm surprised that no one has tried this yet.
Old 12-02-2011, 01:42 PM
samderson311's Avatar
samderson311
samderson311 is offline
i just got 2003 durango slt with totaly broken automatic transmission,and i has 5.9 in it and not 4.7 , i want to swap it to manual , already got a very good and clean AX15 and a manual flywheel plate from Ram 1996 also got the salave and master cylinder and the clutch and brake padles from the 1995 Dakota 5.9 .
my question is durango has holes for the clutch cylinder and for the transmission are there any marks on where i shoud cut in the cab for the trans stick?
Old 12-02-2011, 02:45 PM
whollysheet's Avatar
whollysheet
whollysheet is offline
you will need the cross member from the dakota too along with the pcm from the dakota! it can be done its just time consuming
Old 12-02-2011, 05:37 PM
adukart's Avatar
adukart
adukart is offline
Personally I think a built up 46re would be better than doing a conversion.
Old 12-04-2011, 11:50 AM
samderson311
4x4 360 if you are doing swap from auto to manual (durango) you really must stick around and Dakota models up to 02 if you have 5.9 because they have the Asian AX15 5 speed manual transmission , i have done this swap on my grand cherokee (97) and i just got 2003 durango and i am working on all parts needed plan .... the padles will come from Dak and it will fit just right just a matter of time , you will have to get the hock base for the clutch cylinder from the Dak , manual fly wheel can com from any dodge v8 92 up if yours is 4.7 then NV3500 is a very good choice , fly wheel can come from any 2003 up Dakota ... you may also use the NV3500 on the 5.9 it will bolt except the upper bolt (only one ) and you can still use the dodge fly wheel which comes factory design for the crank position sensor.
Neil H (08-07-2020)
Old 12-04-2011, 04:55 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
I don't think you are going to "need" the Dakota PCM because if you unplug the automatic trans on a 42-46RE they won't cause a CEL, but of course the transmission won't shift automatic either. So with that said, the PCM in your Durango should be fine to run as a manual, at least in my opinion.
I would much rather have a manual verses an automatic any day.
Neil H (08-07-2020)
Old 12-05-2011, 11:53 AM
samderson311
Default PCM 0n 2003 need not change.
yes (hydrashocker) i will not need the PCM from Dakota, i just made a trial start today to my durango with the dodge v8 fly wheel and the AX15 bellhousing (only the front part of the transmission and kept it running for over 45 min it sounded great, i think i will finish this converson as soon i got time the 10 days ......i can not waite to roll it over the Arabian desert sands ,,,,, by the way this is a very beautifull truck ...
Neil H (08-07-2020)
Old 12-05-2011, 04:02 PM
Instant Classic//'s Avatar
Instant Classic//
Instant Classic// is offline
I know a guy who did this with the 318. Was a very smooth conversion. He found a 98 Dakota and basically swapped it all out in a few days. He uses his D to plow, and around here, having the ability to drop down quick is a good thing.
Last edited by Instant Classic//; 12-05-2011 at 04:03 PM. Reason: I haven't been in a Spelling bee since 3rd grade
Neil H (08-07-2020)
Quick Reply: Manual Transmission
