4.7 installing the crankshaft pulley/damper
Old 08-29-2011, 06:37 PM
Lombard's Avatar
Lombard
Lombard is offline
Default 4.7 installing the crankshaft pulley/damper
I know you are supposed to have a special tool to do this, is there any way to get around it? I can get it on with about 1" left to go, but don't want to try pressing it on with the stock bolt because I'm afraid of stripping the threads. Any tips or am I stuck getting the tool?
Thanks!
Lombard
Old 08-29-2011, 07:12 PM
Compactc9's Avatar
Compactc9
Compactc9 is offline
I do know that you can rent the tool from some auto parts stores rather than having to buy it, so if it turns out that you do need it, you won't have to buy another tool that you might never need again.
Old 08-29-2011, 11:19 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Well it looks like you can build your own very easy. A bearing shop should be able to get you what you need to build it.
Old 08-30-2011, 12:21 AM
Lombard's Avatar
Lombard
Lombard is offline
Well, I was able to get it on without the tool. . .just took time and a little TLC. I was able to slide it back far enough by hand (eventually) to get about an inch of threads in on the bolt, and then it tightened right down.
Old 08-30-2011, 11:08 AM
Overcast72's Avatar
Overcast72
Overcast72 is offline
Just noticed that as I was ready to post - good deal. Few tools are an adequate replacement for patience..
But - Autozone in my area will loan a lot of tools out with just a deposit. Lot of others will do the same, don't hurt to call around if you need another one sometime.
Old 08-31-2011, 12:09 AM
Lombard's Avatar
Lombard
Lombard is offline
Yeah, the autozones around here will as well, but no one had anything for the 4.7. . .at all.
Old 08-31-2011, 03:13 AM
modain's Avatar
modain
modain is offline
The bolt is 14mm with a 1.50 thread pitch.
Quick Reply: 4.7 installing the crankshaft pulley/damper
