Cannot find the Fuse Box inside 2003 DGC
Old 08-23-2011, 11:07 AM
rick98Red rt's Avatar
rick98Red rt
rick98Red rt is offline
Default Cannot find the Fuse Box inside 2003 DGC
I found the one in the engine bay on the drivers side. I am having problems with my 12v (always on) lighter adapters. The key on lighter adapter still works.
So I am looking for the fuse that supports the always on lighter adapters
Thanks,
Rick
Old 08-23-2011, 02:54 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
One fuse panel on an 03, under the hood. As I recall you move the fuse from one set of contacts to an adjacent set to change from always on to key on or visa versa. Might be in your owners manual.
Old 08-23-2011, 04:11 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
The key on outlet has a fuse, the battery outlet is a PTC, it is built into the PDC (fuse block under hood)
Old 08-24-2011, 08:46 PM
rick98Red rt
What is a PTC?
So what you are saying is there is no fuse associated with the Battery outlet?
Old 08-25-2011, 09:29 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
It's kinda like a built in circuit breaker. Maybe there is a short in the system
Old 08-25-2011, 11:07 AM
rick98Red rt
Is there a way to reset the circuit breaker?
Old 02-02-2014, 09:38 PM
cng's Avatar
cng
cng is offline
Default Where is the PTC fuse?
Working on a 97 Caravan. I have no power to my evap purge solenoid, and egr solenoid and vac. Wiring diagrams shows the power is from a fuse labeled PTC 1. From the drawings the PTC fuses seem to be on the junction block under dash in a row over the relays. They look like flat thin square ceramic capacitors. Does any one know if I can replace these?
Old 02-03-2014, 11:47 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
No, they are not replaceable. I'm sure some energetic person would tear it all apart and try to solder in a new one but not made to replace.
that PTC also powers the control side of the fuel pump relay. Does the vehicle run?
Old 02-12-2014, 01:21 PM
cng's Avatar
cng
cng is offline
Yes it runs, I had codes for evap purge and egr. Both fed by same fuse. I had no 12v in "key on" position. When I installed an inline fuse from the "key on" power at PDC and fed the purge solenoid it solved my problem. Cleared codes and never came back. THanks
Quick Reply: Cannot find the Fuse Box inside 2003 DGC
