Just put on larger wheels and tires. Is there a way to calibrate the speedometer?
Old 08-19-2011, 07:35 PM
tfrost's Avatar
tfrost
tfrost is offline
Question Just put on larger wheels and tires. Is there a way to calibrate the speedometer?
I went from 205/75 14 to 215/70 15.
Any calibration needed?
Thanks, T
Old 08-19-2011, 08:18 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
The dealer can change your pinion factor in the transmission controller. If that size isn't on the list they can get you closer anyway.
Old 08-20-2011, 05:24 PM
mfahey's Avatar
mfahey
mfahey is offline
The rule of thumb I've always heard was that you could go one size wider if you went down a size in aspect ratio which is what you have done. I went from 215/65/17 to 225/60/17 on our 2001 and the speedometer was perfect when I checked it over a 10 miles stretch of interstate.
Quick Reply: Just put on larger wheels and tires. Is there a way to calibrate the speedometer?
