2007 Dodge Caravan sliding door won't unlock
Old 08-18-2011, 10:18 AM
maestroiam's Avatar
maestroiam
maestroiam is offline
Default 2007 Dodge Caravan sliding door won't unlock
Hi there.
I have a 2007 Dodge Caravan.
Recently, the locking mechanism on the passenger side sliding door started acting up. It locks fine using the power locks but does not unlock. It can be unlocked manually. This is something that has gotten progressively worse over the last few months. Any suggestions as to what is wrong would be appreciated.
Cheers,
Mike
Old 08-18-2011, 11:01 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
Most likely it's the lock actuator, they get weak and finally crap the bed. It's attached to the sliding door latch assembly with one 15 torx screw.
Old 08-18-2011, 11:02 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
The lock actuator goes bad on the sliding doors. You would need to remove the door panel and check the power and ground at the actuator or just replace it.
Old 08-18-2011, 12:13 PM
maestroiam's Avatar
maestroiam
Thanks for the quick replies guys. I actually took the door apart after I posted and I agree with you. Going to the dealer to get the new part now.
Thanks again!
Mike
Old 08-19-2011, 01:40 AM
maestroiam's Avatar
maestroiam
Hi again. Installed the new actuator and it works like a charm.
Thanks for the great advice!
Cheers,
Mike
Quick Reply: 2007 Dodge Caravan sliding door won't unlock
