Help can't find a ground for the amp.
Old 08-17-2011, 04:46 PM
on1wheel01's Avatar
on1wheel01
on1wheel01 is offline
Default Help can't find a ground for the amp.
Well I feel like a audio noob because I can't find a ground at all for my amp. I put my multi meter on where I usually do in vehicles and nothing. I usually use the seat belt ot seat bracket bolts(ground down of coarse) but for some reason i cant get a ground. Where do u guys do yours.
Old 08-18-2011, 12:23 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
My Amps are grounded in the rear cubbie.
IndyD
Old 08-18-2011, 10:35 AM
adukart's Avatar
adukart
adukart is offline
Mine is grounded on the bolt holding down the back seat. Passenger side on top of the bracket. You have to check the threads of the bolt though for a ground.
Old 08-18-2011, 12:46 PM
on1wheel01's Avatar
on1wheel01
I ended up grounding to the floor. Came out to be a very good ground., Later on im gonna add some length in and take it to the frame also.
Quick Reply: Help can't find a ground for the amp.
