wet floor mystery driving me nuts
Old 08-16-2011, 12:13 PM
thunder98110's Avatar
thunder98110
thunder98110 is offline
Default wet floor mystery driving me nuts
windows all rolled up, no visible leaks inside the cab/window trim fine. the floor gets wet UNDER my rubber mat, no water ontop of the mat. only happens when it rains. how is water getting soaked from underneath even when I dont drive it in the rain????
i should add its on the driver side only, right were my right heel rests when its on the gas pedal. parked on level ground.
rained in the middle of the night, go out in the morning and its wet. i dont get it.
Old 08-16-2011, 12:32 PM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
The RAM Administrator
Your HVAC drain tube is cracked or disconnected, is my guess. When I worked for the DOT, one of the state jeeps did the same thing, only it was very noticeable. It would drip on your foot while driving in the rain. Annoying as hell...
Old 08-16-2011, 12:38 PM
thunder98110
it doesn't drip from the top but underneath. how would i go about fixing that?
Old 08-16-2011, 08:14 PM
jkeaton is offline
she leaves a wet spot for you....lol
Old 08-16-2011, 08:38 PM
moparman_2004's Avatar
moparman_2004
moparman_2004 is offline
mine is similar but on the passenger side and i was told that the cowl maybe plugged and hit it with alot of water to flush it out but i guessing you pull it apart and see if you can find a leak trace the wet spot. im sure its going there as it runs down the floor pan
Old 08-16-2011, 08:40 PM
rengnath's Avatar
rengnath
rengnath is offline
I love when you can find it without using a bag of flour! If you need a bag of flour to find the wet spot ...... she's probably too fat.
Rule #1 gentlemen: You can drink em pretty but you can't drink em thin!
Now back to your regularly scheduled topic ....
Old 08-16-2011, 08:44 PM
Eimer123's Avatar
Eimer123
Eimer123 is offline
Did someone say go through the rolls till you smell $hit and go one back?
Old 08-16-2011, 10:01 PM
thunder98110
hah guys, but he side of the trans hump is dry, im positive its coming form underneath
Old 08-16-2011, 10:31 PM
jkeaton is offline
think of a roof leak in the house...water can get in anywhere then it runs down rafters and such and you see the leak come through clear on the other side of the house....maybe something similar, it is running down there during the rain and somehow wicking up from a hole in the floor board, or a small crack, rust area? I'd get up underneath with a strong flashlight or pull the carpet back and check the floor.....
Old 08-16-2011, 10:37 PM
thunder98110
it cant be comming from the top b.c the floor mat is dry. but then i am baffled on how it comes from under when im not even driving. ill take a look tomorrow. but last time i looked, the only thing in that area was a heat shield from the exhaust.
Quick Reply: wet floor mystery driving me nuts
