Help Van keeps shutting off!
Old 08-11-2011, 07:39 PM
ttj_72210's Avatar
ttj_72210
ttj_72210 is offline
Default Help Van keeps shutting off!
I bought a 1997 15 pass. b3500 van to use for my daycare, the van keeps shutting off when I am at red lights or stop signs. It really shuts off the minute you take your foot off the gas. Any ideas of where to start?
Thanks
Old 08-11-2011, 10:34 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Old 08-14-2011, 11:16 PM
ttj_72210's Avatar
ttj_72210
Ok, I have tried cleaning the IAC, but still has the same problem. Any other suggestions?
Old 08-15-2011, 01:24 AM
alloro's Avatar
alloro
alloro is offline
Then it might just need a tune-up. Did the previous owner give you any idea when the last one was?
Old 08-15-2011, 09:12 PM
ttj_72210's Avatar
ttj_72210
The previous owner stated that they did want to invest any money in it becasue they were buying new vans for their church. So Im going to make the assumptions that it has not been tuned up in while.
Old 08-15-2011, 10:52 PM
Rusty93RamVan's Avatar
Rusty93RamVan
Rusty93RamVan is offline
So you can probably guess the next advice -- time for a tune up.
Spark plugs, ignition wires, distributor cap, rotor, engine oil, oil filter, air filter, PVC valve, crankcase breather & chassis/steering/driveshaft lube.
It would also be an excellent idea to check the front & rear brakes, differential oil level & transmission fluid.
Good luck with your new van.
Quick Reply: Help Van keeps shutting off!
