2005 dodge stratus 2.4 dohc crankshaft position sensor
Old 08-10-2011, 06:45 PM
cslater1218's Avatar
cslater1218
cslater1218 is offline
Default 2005 dodge stratus 2.4 dohc crankshaft position sensor
I have a 2005 dodge stratus dohc 2.4. I do not know where the crankshaft position sensor is located I was wondering if anyone could help or had a picture of the location of the sensor i wish to change it myself cause the mechanic is trying to overcharge me... thanx
Old 08-11-2011, 12:33 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
REMOVAL - 4 CYLINDER
Disconnect the negative battery cable.
Remove the air cleaner box (Air Cleaner Housing).
Loosen and relocate the starter motor.
Disconnect the electrical connector.
Remove crankshaft sensor bolt.
Remove the crankshaft sensor.
Quick Reply: 2005 dodge stratus 2.4 dohc crankshaft position sensor
